throttle cable
Old Jun 3, 2007 | 06:44 PM
nitetrain's Avatar
nitetrain
Default throttle cable
OK, I'm changing my throttle and idle cables, do I need to raise the tank, or can I snake'm under and avoid all that work? 05/train
Old Jun 3, 2007 | 06:49 PM
nitetrain's Avatar
nitetrain
Default RE: throttle cable
Sorry for the double post.
Old Jun 3, 2007 | 07:07 PM
20NightTrain03's Avatar
20NightTrain03
gary-
i had to remove my tank
worst part is draining the gas as there is always a little left in their
if i remeber correctly there are a few clips that hold them to the frame under the tank so i dont really think fishing them through is an option
hope to see you next sunday!
-Glenn
Old Jun 3, 2007 | 07:14 PM
nitetrain's Avatar
nitetrain
Thanks Glenn, I'll be there for sure the 10th. Did a ride this morning with sinner and his buddy Doug. Nice ride down 520.
Old Jun 3, 2007 | 07:39 PM
DaveJ's Avatar
DaveJ
I already had my tank off when I did mine. But perhaps you could just loosen the front bolt a bit to allow it to pivot and remove the back bolt; then lift the back of the tank and block it with a 2x4 or something. You may have to disconnect the fuel line, but that doesn't require draining the tank.
Not sure if that would give you enough clearance, but just an idea.
[align=left] [/align]
Old Jun 4, 2007 | 10:53 AM
oldgeezer's Avatar
oldgeezer
I replaced the throttle and idle cables on my Standard without taking off the tank. I just fed them through to the carb. Might be different if you have EFI.
TylerBoehm
Jun 7, 2014 06:55 AM
msamarah86
Jul 12, 2011 08:57 AM
roofer
Nov 15, 2007 11:32 AM
bpdeepwater
Sep 2, 2007 06:51 AM
KBES BAGGER
Jan 28, 2006 01:20 PM
