Am I just dumb or do I have a problem
Old Apr 8, 2017 | 12:34 PM
ddb's Avatar
ddb
1st Gear
Default Am I just dumb or do I have a problem
I bought a 2001 softail heritage with only 1800 miles a month ago. Today is the first nice day since purchase so went to take a ride. Gas gauge shows about an 1/8 full so went to fill up. The stupid gas cap won't come off. I can turn it but it won't release. Do I have a problem or am I just stupid?
Old Apr 8, 2017 | 12:37 PM
MURPHCC1's Avatar
MURPHCC1
not sure about that type of cap.......but maybe put some DOWN pressure on it while turning?
Maybe some UP pressure?
Wonder if the top part of the cap came dislodged from the lower section......im sure someone around here will help you out.......they're good like that!
Old Apr 8, 2017 | 12:42 PM
bad tappets's Avatar
bad tappets
Which gas cap are you trying to remove? If you're trying to remove the left side with gas guage, then no that won't work. Remove the right side. Might be stuck from lack of use, give it a good twist counterclockwise when looking down on it.
Old Apr 8, 2017 | 12:46 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Welcome to the forum, and congrats on your new to you bike!
Like b t said, loosen the one on the right, the one on the left is non-functional as a gas cap.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
ddb's Avatar
ddb
1st Gear
I pushed down and also up while turning. It won't release. Has anyone ever had a gas cap that was stripped?
Old Apr 8, 2017 | 01:12 PM
matte's Avatar
matte
Sounds to me like you have a flush mount cap. Mine did this on my last bike. Anytime my gas got low, back pressure would make it impossible to move. First time it happened, I used something as a wedge to get it to break the seal. After that I just used my fingers. May need a new cap too.
Old Apr 8, 2017 | 01:15 PM
matte's Avatar
matte
By anytime, I mean it started doing it about a year after I installed it. Scared the heck out of me the first time because I had just enough gas to get home and no tools or idea what the problem was.
Old Apr 8, 2017 | 01:19 PM
ddb's Avatar
ddb
1st Gear
It's not flush, looks like a stock HD cap.
Old Apr 8, 2017 | 03:21 PM
gtmalone's Avatar
gtmalone
Squirt a little WD40 around the cap and let it sit for awhile then try it. Probably stuck from not being used.
Old Apr 8, 2017 | 03:29 PM
RANGER73's Avatar
RANGER73
Sounds like it you can turn it that the top chrome piece has separated from the plastic threaded part. Get a new one, and a large pair of pump pliers. Squeeze the top and turn. You're going to screw it up, that's why I said get a new one.
