Heat from exhaust!!! HELP!
Old May 10, 2017 | 07:33 PM
Rollon's Avatar
Rollon
Default Heat from exhaust!!! HELP!
Went riding today and the temp was about 86 F. When stopping for stoplights the right side of the Heritage was really hot (muy caliente!!). I found myself putting my right leg on the footboard to avoid the heat! Anyone changed the exhaust and had a significant reduction in the exhaust heat?? If so, what did you do? If you have a thermal sensor would you measure the temp and provide them? I can measure the stock system for comparison.
Thanks for your help!!!
Old May 10, 2017 | 07:39 PM
SamStone's Avatar
SamStone
A stage 1 , tuned correctly, will significantly reduce heat. Along with a Captain Itch heat shield, you'll be comfortable.
Old May 10, 2017 | 07:52 PM
r1cochet's Avatar
r1cochet
It's the catalytic mesh in the muffler. I swapped the mufflers with Cycle Shack slip-ons. It's still a hot muffler right where your leg touches the ground though...
Old May 10, 2017 | 07:54 PM
HDnoob's Avatar
HDnoob
I agree with samstone. I had an improper tune on my bike with a stage 1 thanks to a Vance n Hines fuelpak. Ditched that thing for a power vision and proper tune. Cooled my bike down significantly.
Old May 10, 2017 | 08:00 PM
wyndnface's Avatar
wyndnface
check out Captain Itch crotch cooler
http://www.shop.captain-itch.com/Har...hields_c58.htm
Old May 10, 2017 | 08:37 PM
Rollon's Avatar
Rollon
How will the Captain Itch help with the exhaust heat?
Old May 10, 2017 | 08:42 PM
r1cochet's Avatar
r1cochet
Blocks the radiant heat from the rear cylinder exhaust port/pipe and the oil tank that is right by your right thigh...
Old May 10, 2017 | 08:48 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Captain Itch is your friend
Old May 10, 2017 | 08:52 PM
Norky's Avatar
Norky
Slip ons and intake made a big difference on my heritage. still hot, but not nearly as bad.
Old May 10, 2017 | 08:57 PM
Rollon's Avatar
Rollon
Norky, what slipons and intake did you use? Thanks
