Idle Control Harley Davidson
Old May 16, 2017 | 07:27 AM
Softail65's Avatar
Softail65
Default Idle Control Harley Davidson
Hello,
I bought this part for my softail (2011)
What can I say, I love it !
http://www.american-motors-usa.com/t...tail-2006-2016
My wife has installed the idle control in the sportster, it's like a new motorcycle
Old May 16, 2017 | 08:33 AM
stal94gt's Avatar
stal94gt
It looks like a well built product. I would do some research to see what is the lowest rpm your bike can be at before your oil pump pressure drops below an acceptable psi. Also the new tuners allow you to adjust your rpm down to 800 rpms threw the computer
Old May 16, 2017 | 09:00 AM
Otter's Avatar
Otter
"Receive the Old Harley EVO Sound"
At 600rpm, you will also likely "receive" engine damage from lack of oil flow.
Old Apr 8, 2024 | 04:15 AM
slonez_sg's Avatar
slonez_sg
Did you leave the stock IAC connected or unplug it?
I am also considering this. Thank you.
Old Apr 8, 2024 | 04:39 AM
smitty901's Avatar
smitty901
Put a good set of cams in or cam depending on engine. Running Idle below 950 will cause damage on TC and M8 period. No magic trick will change that.
Old Apr 8, 2024 | 11:47 AM
08xl1200r's Avatar
08xl1200r
I'm not the OP but that thing replaces the IAC, you can't have both. IIRC Fuel Moto says that 950 rpm is the lowest idle speed that delivers acceptable oil flow to the heads so that is what I use on my Sportster (via a Powervision tuner) and my carb'd Evo big twin.
Softail65
Harley Davidson Videos
May 5, 2019 03:24 PM
scottdavis69@gmail.com
May 21, 2016 08:29 PM
Softail65
Jun 16, 2015 10:43 PM
hamdizle
Mar 30, 2012 09:35 PM
jwiz
Sep 10, 2006 09:29 PM
