Battery Fuse
Old Jun 5, 2017 | 11:30 AM
Lonny Spiva's Avatar
Lonny Spiva
Former Sponsor
Default Battery Fuse
I have a 2008 Rocker that has 3 miles on it, Yes "3" It was been setting around the Heartland USA shop for 6 top 7 years, Now I need it to Run.
Put New Battery in Bike and Key Fob. When I try to start and then put key in Off position - the Battery Fuse POP's
Any ideas? of why?
Old Jun 6, 2017 | 01:51 AM
jkinner's Avatar
jkinner
Does it start? what amp fuse?
Old Jun 6, 2017 | 10:51 AM
Lonny Spiva
Former Sponsor
Yes the bike will start, 15 amp fuse.
Old Jun 6, 2017 | 01:37 PM
jkinner's Avatar
jkinner
Have you tried the kill switch then turn off the key? If my memory is correct a Rocker has to have the key in the ignition right? My Deluxe all I need is the fob.
Old Jun 6, 2017 | 01:42 PM
Lonny Spiva
Former Sponsor
Yes the Key has to be in the Ign. Changed it on the Breakout.
Good question, I'll try that today. Thanks
Old Jun 6, 2017 | 01:54 PM
Lonny Spiva
Former Sponsor
Yes, It still Blows the Fuse
Old Jun 6, 2017 | 02:56 PM
jkinner's Avatar
jkinner
I would try this, leave the key in the on position start it and then shut it off using the kill switch, leave the key on and try to restart it. Other then that sorry, I am out of ideas.
Old Jun 6, 2017 | 03:24 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Food for thought, the fuse was good before you started tinkering with it?
Old Jun 6, 2017 | 03:25 PM
stal94gt's Avatar
stal94gt
I am not sure what fuse you are talking about cause if it is the 45 amp fuse from the battery than it is probably shorted out on the frame. You can chase that wire fairly easy cause it runs up the spine of the frame
Old Jun 6, 2017 | 04:00 PM
Lonny Spiva
Former Sponsor
The Main is the 45 Amp.,,,, this is the 15AMP yellow one in the center of the Fuse Cluster. marked as 'Battery"
dh_meyer
2014-2024 Touring Models
17
Aug 15, 2018 12:47 PM
JY Kelly
Mar 3, 2013 11:32 AM
HDUK
Jul 2, 2012 12:59 AM
blackfatbob
May 5, 2011 08:07 AM
Turbo3pt3
Mar 15, 2010 10:10 AM
