My Rocker C/Breakout build
Old Aug 12, 2017 | 05:20 PM
  #31
Rocker B's Avatar
Rocker B
Originally Posted by Sarah93003
I don't recall reading anywhere in your threads, but have you compared your Rocker to your Breakout as far as a performance shootout perspective? Is one decidedly faster than the other?
Basically, my Rocker with its 30/70 pulley mod and the S&S 583C cams is stronger off the line, 1st-3rd gear, it would get the edge, then the BO with the 103 and Andrews 37H cams, would pull away. I'll give a more detailed comparison on one of my threads, so I don't clutter up Tommy's.
Old Aug 12, 2017 | 07:52 PM
  #32
TOMMYBLAZIN's Avatar
TOMMYBLAZIN
I was told the 96's are faster by 3 different motor builders and that Harley only cares about displacement for people who don't have a clue, look at the numbers Harley's screaming eagle 110 puts out??? Not even 100 HP, NOT IMPRESSIVE AT ALL, My TQ numbers going to be WELL over that....and ill have a 107'''' don't get stuck on the displacement like I did........I pull on a buddy's breakout all the time...honestlly even before the gears...than again, he is a bit of a lolly girl....im much more aggressive all the way around....
Old Aug 12, 2017 | 07:58 PM
  #33
TOMMYBLAZIN
Originally Posted by Hawaii-Five-Jo
Love seeing Rocker builds. You must be excited to get it started.
I am, bought it last year, According to wife and spreadsheet I put over 7k into it, has a custom painted breakout rear fender, struts etc, I did the gear mod, theres another 1500..lol.. but this is where the real build comes, in , more than look at me....when I ride with my buds, which is often, thats where the funs gonna shine....chrome rims and cable can wait...BUT THEY WILL BE THERE HAHAHAH.,.,.,.after this build is over, around winter, I have a long list starting with suspension first....stay tuned, this is NOT gonna be like any other I guarantee that, I finally got with the right people, and a mechanic shop I TRUST, and a painter,,,, so like I said stay tuned......PAINT
Old Aug 12, 2017 | 08:04 PM
  #34
TOMMYBLAZIN
Originally Posted by Rocker B
It's gonna be sweet!! I'm curious what made you go with the TW 6-6? It's specs are very similar to the Andrews 37H cams I have in my Breakout, which, like the TW6-6 is a mild 510 lift cam, with an intake close at 38 vs.40 on the 6-6, and it doesn't really come on until around 3k RPMs. With the intake close at 40, the 6-6 should come on even a little later then the 37H, and I thought you wanted a cam with the peak torque down in the low/mid range....Just wondering why you went the other way??
the cam comes on immediately, and my builder, I'm going off what he says, I had nothing to do with it, I had a 583c at my house, and when I returned him AND my mechanic said it was the right move, there a lot of people on here that Hillside from NY did 107' build forts well as others, but he knows how to build around the cam, the numbers might say this or that, and I asked him cause it said its a STOCK cam, he said forget that, I'm not doing just cams, were building a entire motor, throttle body, injectors....full monty...but the cam off there website says it pulls from idle...these are expensive cams, and after holding both, I see why, there is a definite difference..im trusting my builder, I could by any cam I wanted, he knows my weight, my bike, and what I want, this is what the dr ordered.....
Old Aug 12, 2017 | 08:06 PM
  #35
TOMMYBLAZIN
W6-TW6 This is the cam
http://www.woodcarbs.com/cams.htm
again, this is the smallest part of build the lifters cost just about as much lol...they are revolutionizing products...
a Directional lifter???, if you read up, no one out there, even SS best lifter compares...no lift limit on twin cams, awesome, its not just the lifter its what it does with the oil, the bleed down rates, I read up on these products, and I want them.well I have them now..hahah
http://www.woodcarbs.com/dirlifters.htm
Old Aug 12, 2017 | 08:44 PM
  #36
TOMMYBLAZIN
o boy I hope I got right ones, I saw these....
W6H
TW6H
so close, and these say hi lift....the ones I have says stock springs, I know if anything my springs are FAR FROM STOCK, Rocker B you might of saved me from a huge eff up man!!! holy ****......
u saved my *** again, these are wrong cams, holy **** I was going to take on Friday to mechanic than something said wait,...now I have to return these, I need to get this **** sorted out, I'm spending way to. much god damm money for this to happen twice....
Old Aug 12, 2017 | 09:09 PM
  #37
Rocker B's Avatar
Rocker B
W6H
TW6H
Ya, if you like Woods, and you want the torque to the right a little, like the TW 6-6, look at the TW777 or TW888. If you want to keep the lower 510 lift, then the TW 222 the "Triple Deuce" looks like a nice option, intake closes at 34, so it should be a little stronger down low then the TW 6-6....Don't get me wrong, the numbers the TW 6-6 can be very impressive in a 107, the peak torques just a little more to the right of the curve then I thought you were looking for. I also thought with a build like yours, you might go with a little more aggressive cam.
Old Aug 12, 2017 | 09:49 PM
  #38
Rocker B's Avatar
Rocker B
W6H
TW6H
The stock springs will handle up to 590 lift, check it out, but I think usually the compression needs be set higher then 10.0/1 when using 600+ lift cams, but there may be exceptions to that....also, you can't believe everything you read, my Andrews 37H cams don't come on near the 2200RPMs that the Andrews site says, but if I knew about intake close numbers and how they relate to the torque curve, before I bought and installed them, I would have known that... The cam spec numbers and dyno sheets are the only way to really know where a cam will be strongest!
Old Aug 12, 2017 | 10:10 PM
  #39
cdonis's Avatar
cdonis
A 107 with the tw6-6 pops 125+/125+, I would be astonished. Most cam manufactures seem to have great results when looking at their website dynos. Surprise surprise!
Old Aug 12, 2017 | 10:20 PM
  #40
Rocker B's Avatar
Rocker B
I was sorta thinking the same thing! ...and hey man, I just saw your post on the Breakout thread....I shouldn't, but I've just got know what your asking for the jugs and heads...Check your PM.
