lights
Old Jun 25, 2017 | 07:31 AM
popcorn13's Avatar
popcorn13
Default lights
hi, have a 03 heritage softail checked bike over yesterday for a morning ride today. everything good lights brakesw ran great. today turned on ignition and only head &tail light on bike starts and runs. have no dash, brake ,signal lights. every time i turn ignition on the 15 amp fuse blows. tried this 2 times. i am thinking ign.switch went bad overnite. any other ideas are very welcome thanks
Old Jun 25, 2017 | 07:35 AM
davidwruth's Avatar
davidwruth
When a fuse blows like that you are shorting to ground. Have you done any recent mods to the bike? You should check those first. After that I would start taking bulbs out one at a time until it stops blowing. At least then it would give you some idea which wires to check.
Old Jun 25, 2017 | 08:18 AM
popcorn13's Avatar
popcorn13
Default light
no mods, everything worked fine yesterday afternoon.
Old Jun 25, 2017 | 08:24 AM
duoglider's Avatar
duoglider
check for frayed wire shorting against frame somewhere in the wire path
Old Jun 26, 2017 | 10:10 AM
2WheelNut's Avatar
2WheelNut
I would try using an ohm meter to see if the lights, ignition switch etc is shorted to ground that shouldn't be.
keno
Sep 20, 2014 01:39 PM
knights
May 3, 2014 09:27 AM
cmose
Mar 24, 2012 03:40 PM
sictail
Sep 24, 2006 09:43 PM
mike b
Feb 12, 2006 02:29 PM
