Hey Tom I thought the later evo's had one under the nose cone, the cam pick up sensor had a lean sensor to shut the bike off if it were dropped. the early ones were plain an the later ones had that black block thing that contained it.
cycle the key a few times or disconnect the battery for half an hour.
After some research you are correct..96 up had a "Vehicle Attitude Sensor"...basically the same thing...and they are notorious for failing...word is if yours is dead...get an ignition-sensor-plate that doesn't have one.
