Hello from Florida ! ! I have a 2004 softtail night train with light issues
Old Jul 31, 2017 | 07:22 PM
Skulltail's Avatar
Skulltail
4th Gear
Default Hello from Florida ! ! I have a 2004 softtail night train with light issues
I don't know if this is the right place to put this ? On the left side all lights are working fine, NOW .. the right side only the front right riding light is on, right side no turn signals work at all ( led lights ) frt and back, I manually tested left & right side turn signals, they all work fine. The rear turn signals are only blinkers , The left good side blinkers work fine front and back. Headlight low and high beam works fine.Emergency 4 way blinkers only left side frt and back works, right side no blinking of any kind, only the front right turn signal riding light is on only, right side not blinking at all, right side frt and rear will not work at all. Please someone help me, I am scratching my head with this one. Please. HELP !! Me out. Skulltail ( Tim ) Thank you.
Old Aug 1, 2017 | 08:44 AM
the blob's Avatar
the blob
Check the easy stuff first, wires,grounds and bulbs. If all look good I'd take a look at the turn signal module (tsm). I believe it's located behind the rear splash guard.
Old Aug 1, 2017 | 09:23 PM
back again's Avatar
back again
TSM could be culprit but other things should be checked first that don't cost you anything.. Remove seat and make sure main ground to frame hasn't come loose or have rust around it. Good time to pull the bolt grind the powder coat on frame and coat with die electric grease. If you still have issues I'd take tank off and check your main harness plugs. They have been know to come loose and cause the problems your having.
SixtyFourPanhead
Mar 18, 2019 09:09 PM
John Secosky
Apr 28, 2018 07:07 AM
Krudnits
Electrical/Lighting/Alarm
30
May 1, 2015 07:57 PM
Rollbar
Feb 11, 2015 08:00 PM
acd118
Jun 3, 2011 08:24 PM
