Left front turn signal not working?
Old Mar 18, 2019 | 12:59 AM
SixtyFourPanhead's Avatar
SixtyFourPanhead
Stage IV
Default Left front turn signal not working?
Hello, working on a 1994 Harley Davidson Softail FXSTS. It has regular bulb turn signals front and rear, I have a led tail light with integrated running, brake, turn indicators built in. Right front and rear work perfectly as well as left rear. The problem is only front left does not light or blink at all. Have been trying to track down short so far to no avail, my train of thought is I can rule out the switch at the controls as the left rears work? I have no load equalizer as the tail light draws barely anything. Bulbs and sockets are all 100%, any ideas or input would be very much appreciated, Thank you!
Old Mar 18, 2019 | 02:36 AM
AKL1's Avatar
AKL1
Did you check the voltage at the lamp. when it´s supposed to blink?
Old Mar 18, 2019 | 04:08 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
When did it stop working?
Can you attribute it to some work you have done or changes you have made?
A short circuit usually to ground would result in a blown fuse.
A load equaliser is for the indicator relay or electronicss that require enough amps to get them to flash at the correct speed. It may also be necessary for systems that show bulb health. If only a small current flows it may think a bulb is blown.
Get a multi meter that has a continuity setting. Remove the battery. Trace the wires from the bulb holder to the connector and check them for continuity.
Old Mar 18, 2019 | 04:17 AM
Billy889's Avatar
Billy889
+1
Old Mar 18, 2019 | 12:06 PM
SixtyFourPanhead
Stage IV
I'm want to put mirrors with led turn signals on to replace bullet turn signals, have bullets hooked up now and only front left not working?
Old Mar 18, 2019 | 01:06 PM
Andy from Sandy
Well you will have to go through the process. We can't fix it for you from the other side of the ether.
Old Mar 18, 2019 | 04:42 PM
SixtyFourPanhead
Stage IV
Thank you AKL1, Andy, Billy, I am working on all your suggestions, it is very much appreciated!!! By the way AKL1, I am Danska as well!
Old Mar 18, 2019 | 09:09 PM
SixtyFourPanhead
Stage IV
Found the problem, loose pin in the connector under the right tank, again I thank you all very much!!!
Robotech
Jun 10, 2019 09:12 PM
kberger
Electrical/Lighting/Alarm
Aug 6, 2017 01:07 PM
broncobob
Jul 5, 2013 11:10 AM
King_O_Road
Jul 9, 2011 08:07 PM
stoneman
Jun 24, 2007 04:32 PM
