Primary chain adjusters
Old Jun 12, 2007 | 11:31 PM
bikerbehaviorist's Avatar
bikerbehaviorist
Default Primary chain adjusters
I did a search and did see some talk about this but no real answer to the two following questions:
Is it worth the $100+ ?
Which one should I use?
The H-B hydraulic looks very good
The M6 looks like I would still need to do maintence every 10-15k so why bother
The harley from what I read in my search tends to to tighten too much.
So the H-B?
What you'all think?
Old Jun 13, 2007 | 03:44 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Primary chain adjusters
IMO, an auto tensioner is an unneeded luxury. I have had to adjust my primary chain once in 65k miles. It's not hard to stick a finger in the hole and check it every time you change the primary oil. Besides, an auto tensioner is not a set and forget item. The shoe is still gonna wear out and needs to be checked every now and then.
Old Jun 13, 2007 | 07:57 AM
Mikey 1450's Avatar
Mikey 1450
I would stick with the factory set up. It does its job andlast longer than many will ride.
Old Jun 13, 2007 | 08:10 AM
sleepneagle's Avatar
sleepneagle
I run an M6 and wouldn't have anything else. It applies the correct amount of tension and prevents any primary slop. shifting is improved and you eliminate the clunk. No maintanence is required, just visually inspect when you do a primary oil change.
you can buy for less than a $100 from Wallys Cycle World and several others.
Old Jun 13, 2007 | 10:50 AM
Zzack's Avatar
Zzack
I was looking at the M6 too. Checked out Wally's Cycle World as suggested here. Great price at $75.00. Thanks for the information.
I've also heard mostly good things about auto tensioners and M6 in particular. From quieter clutch operation to smoother shifting. I'm sold and will be ordering the M6 today.
--Z
Old Jun 16, 2007 | 04:44 PM
azazruk1's Avatar
azazruk1
Sleepneagle-
How is the install on that? Looks about as easy as taking off the primary, maybe 2-3 hours at the most I would guess??
Thank you.
natural gasser
EVO
16
Aug 22, 2019 09:43 PM
DavidStiebel
Nov 25, 2015 08:57 AM
azharleyrider86401
Apr 8, 2011 05:43 PM
deadman77
Jan 4, 2009 06:51 PM
steveh326
Jan 27, 2008 05:48 PM
