Stage 1 and Fuel management question
You also need to know what changed (as compared with the stock/one you're replacing) with that "canned" tune. For example... If you download a tune for a '09 Sportster sporting a SE AC and V&H Short Shots, what will you find that's different from the stock tune? You'll initially might be a little surprised because it doesn't look like much changed. The Spark tables are essentially untouched. AFR's are changed from 14.6 to 14.5. That last part forces it into open loop operation. You might ask why they would do that... Well...It's not until you look at the VE table deltas that you find out the significant change in the tune. They enrich (significantly?) a lot of what normally is the closed loop operating range by adjusting the VE values to provide more fuel. For that to work, it needs to run open loop. Now a lot of folks might want to play with their new gadget and try out that "Auto Tune" thingy. If you do that after flashing this "canned map" you may have just trashed it (you'll likely undo the enriching that was done by the VE changes).
Now... You may ask... What if the enriching done to the VE tables is just the necessary changes/calibration required by the SE AC/Short Shots to make the VE tables accurate? Ok. Could be all that it is. But then why take it out of closed loop and run open loop by changing the 14.6 AFR table cells to 14.5 (hardly a change worth doing - in and of itself)? If the VE table deltas were simply a matter of calibration, then you'd leave those AFR cells set to 14.6 and take advantage of running closed loop.
If I had it to do over again, I'd just bite the bullet.
Now more questions than answers. Awwwww....
I noted that closed loop control/adaptive learning may compensate for the errors introduced by the SE AC and slip-ons. "May" is the key term. But so what if it did? You still are running a stock tune and all that comes with that.
When I bought my Nightster, the PO had installed V&H Side Shots on it. It still had the stock tune in it. Stock AC was still on it. How did it run? It ran, but needed improvement (various issues). Long story short - VE cals have been done and a lot of the leanest has been fattened up in my tune since then and it runs well these days.
My point is, you could try to run it without tuning and it may well compensate for your changes. But, it likely could be made to run better with some decent tuning. You are no longer hampered by a warranty, so you got room for more improvement.
What would I do in your shoes...
If I really didn't want to deal with it, I might just go and have a competent pro do a tune. The hard part might be in finding a "competent" pro.
Or...
You could simply call Fuel Moto and get a PV. They'll likely have a canned map that may very well do the job. They certainly have very good support and can help you with the learning curve. I do suggest that you look at and understand the changes that are being made by the new tune. As you dig in and figure this stuff out, you might have curiosity about auto tuning, which is fine. Just know that it's not really auto tuning. It's an attempt to calibrate the VE tables. Based on what you have, you may decide it's something you want to do.
One more note. Unfortunately, the documentation that comes with some of these devices is poor (DynoJet's being no exception). This complicates the learning curve. If I remember correctly, the Master Tune/TTS manuals were pretty good (they do a better job with the theory - what you are doing, not just the how). Although things in those manual of for their product, the theory is the same.
Or...
Considering that looks like Fuel Moto maps are close to what people get with auto tune I am tempted to go this way somehow as who knows when I will do cams or maybe 110" kit and this always give me option to send module back for reprogramming for new upgrade. $260 for this option sounds like money well spent considering what are other options.
So far it will be Power Vision or sending module to Fuel Moto. I guess it is time to speak with folks at Fuel Moto or ride there to get the job done.
in case I want to install SE air cleaner while I already have SE slip ons should I worry about any engine damage in case I want to ride it like that for let say 500 miles?
FP3 supports upgraded cams so it will get you to stage 2.
The software is always being updated and will just get better as time goes on. People just like to pick on it.
I think you have to ask yourself "do you have to have the SE air cleaner on now, or wait until you get the appropriate fuel computer?" You can probably still have fun riding the bike the way it is currently.
