Removing 2-2 exaust
Old Nov 11, 2017 | 11:24 PM
TOMMYBLAZIN's Avatar
TOMMYBLAZIN
Thumbs up
Originally Posted by Rakthi
I torqued the ones I could reach without the flexible to spec, the one I needed the flexible for I just tightened on "feel"
100 - 120 in/lbs is not that tight and you have the others to get some sort of idea of the force needed.
Checked the nuts a couple of times over the first 1000 or so Kms but all secure and stayed so for the next 25,000+ Kms.
The torque on those nuts is more to prevent you to strip the threads.
RB racing spyder pipe ... yum! Nice one!! Will need to see pictures when installed.
will do, 4-6 week build time.....good things come to those that wait, I have a build thread going, I've done LOTS TO THIS ROCKER C,just over 3k miles, did a Hillside 107ci build, etc...got a lot going on, Baker products going in now.....
Old Nov 11, 2017 | 11:30 PM
langwilliams's Avatar
langwilliams
here you can see how the end where the socket goes isn't square so there's some play allowing the socket an extention not line up perfectly an work
https://www.harborfreight.com/3-piec...set-67066.html
I have a few of the universal type like the one pictured in post #7 but they can be bulky in tight spots
Old Nov 21, 2017 | 02:45 AM
TOMMYBLAZIN
I gave the heavy duty impact desalt like that, but I didn't try as I thought threaded rid would bottom of socket?
Old Nov 21, 2017 | 12:18 PM
Oldskewl's Avatar
Oldskewl
https://store.snapon.com/Dual-80-174...t-P647033.aspx
The proper ratchet will get you where you need to be.
Old Nov 27, 2017 | 09:27 PM
TOMMYBLAZIN
I appreciated snap on, I truly do, duty I have heads , actually thinner, never thought of it, but a swinging head, a deep socket, with whichever head size would do it thanks...
Old Nov 28, 2017 | 05:59 AM
j33ptj's Avatar
j33ptj
Did you remove the heatshields? With out the heatshields access is much better with a deep socket...
Robert
Old Nov 28, 2017 | 09:30 AM
Oldskewl's Avatar
Oldskewl
Yea, Snap-on is expensive AF but they always have a tool that gets your socket right where it needs to align up with the nut. Glad it all worked out.
Rise_
Aug 12, 2019 01:45 AM
Geriden
Jun 11, 2016 03:23 AM
Ragnar Danneskjöld
Aug 8, 2012 08:44 PM
bigdog1949
Wheels/Tires
Feb 10, 2012 09:55 AM
HarleyHog59
Mar 16, 2009 07:04 AM
