M8 Softail listed on latest Sumping TSB
Old Nov 22, 2017 | 09:42 AM
Thingfish's Avatar
Thingfish
Default M8 Softail listed on latest Sumping TSB
Thread over on the M8 section about new sumping TSB. All Softails are listed with oil pump before 10/10/17, not just Stage 3 or 4. Good news is no one here is reporting sumping yet AND Moco is acknowledging the issue...bad news is we're not immune most likely.
https://www.hdforums.com/forum/milwa...changes-2.html
Old Nov 22, 2017 | 11:47 AM
Tom84FXST's Avatar
Tom84FXST
And they are really going to confuse everyone calling a scavenge issue "sumping"
Old Nov 22, 2017 | 12:53 PM
adm's Avatar
adm
Well that's definitely a bummer. However, I haven't noticed any loss of power of excessive engine braking so far and I have done quite a lot of extended high RPM runs....
Thanks for posting the service bulletin. Now filed away in Evernote in case I ever do experience the issue and need to show the dealer....
Old Nov 22, 2017 | 05:41 PM
Thingfish's Avatar
Thingfish
Yes, same here. Fingers crossed for continued good luck, but if it comes time for new motor after 25,000 miles....I'll take it.
Old Nov 22, 2017 | 07:17 PM
GPHDXLC's Avatar
GPHDXLC
Bummer!!! I wonder if a bike built after 10/10/17 is really safe ??
Old Nov 22, 2017 | 07:28 PM
Pothole914's Avatar
Pothole914
So, how do you find out the production date of your bike?
Old Nov 22, 2017 | 07:35 PM
triumph900's Avatar
triumph900
Well, this sux. I wonder if this is a question of IF this happens or WHEN this happens?
Old Nov 22, 2017 | 09:09 PM
badcooky's Avatar
badcooky
It's for stage 3 or 4 Softails I'm pretty sure !
OK page 5 is just an example!
Old Nov 22, 2017 | 09:24 PM
Thingfish's Avatar
Thingfish
Believe it's on the frame. Dealer can probably answer as well.
So far lots of '17 and '18 bikes don't seem to have any problem and many touring M8s have high mileage. It's why I'm protecting my warranty for now.
It also lists stock 107 and 114, but I think the stage 3 and 4 have higher likelihood. Read the M8 threads, it's a wide range of factors that can come into play. The TSB is covering all M8 models.
The trans fluid migration TSB lists all bikes with hydraulic clutches even prior to the M8, but very few of the Rushmore touring bikes with those setups had issues. TCs have dumped under the right conditions so it's not entirely just an M8 problem, but something in the design has increased the occurrence. I still think most of us will be fine.
Old Nov 22, 2017 | 09:32 PM
badcooky's Avatar
badcooky
https://serviceinfo.harley-davidson....Z.c432ad220bd3
Check your VIN against the part number !
