Jiffy stand, will 2011 fit an 05
Old Dec 1, 2017 | 10:42 PM
nzhd's Avatar
nzhd
Default Jiffy stand, will 2011 fit an 05
Hi everyone.
Just wondering if anyone knows if a 2011 Fatboy jiffy stand will fit a 2005 Fatboy?
Thank you.
Old Dec 1, 2017 | 11:46 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Yes it will.
Old Dec 1, 2017 | 11:47 PM
nzhd's Avatar
nzhd
Thank you!
Old Dec 5, 2017 | 06:33 AM
LukeRyanD's Avatar
LukeRyanD
The short answer is yes and no. It will not be a direct swap, as I assume you are asking. The method in which it "stops" is not the same between the two. The '05 uses a square "tab" on the top of the jiffy stand. The '12 has a "block" on the shaft that stops the stand from riding forward, and rides on a clevis pin and bushings.
You can use it if you also replace the floorboard brackets. I installed floorboard on my 05 FXST that came off of a '09 crossbones. I was not able to use my old stand, as they were different.
2005 FLST See parts 19 and 20
http://partsfinder.onlinemicrofiche....0JIFFY%20STAND
2012 FLST See parts 1, 15, 16, and 19
Hope this helps
Old Dec 5, 2017 | 12:19 PM
nzhd's Avatar
nzhd
thank you. I see what you mean.
I have forward controls. so I'm still a little unsure. but it is on its way, it was fairly well priced so will just try and see how it goes.
BigBrainBob
Aug 23, 2020 06:01 AM
Buckinfitch
Oct 9, 2017 10:38 AM
eggs1959
2014-2024 Touring Models
13
Mar 13, 2016 05:02 AM
retxpres
Mar 14, 2015 09:14 AM
JesseT
Apr 27, 2012 09:52 PM
