Hey guys and girls! I’m doin a service on my 04 super glide sport and I’ve dumped the gear oil but when I started to refill it, it overflowed! I’ve only put 500ml (17 fl oz) in and it should take at least another 200ml (7 fl oz)
also I thought maybe there might be a blockage so I took the drain pulg out to see if any oil had made it to the bottom of the pan and no oil came out
HELP!!!
Did the "gear oil" you drained out look like engine oil?
Welcome to the forums!
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
