2018 Fatboy oil light
Old Feb 3, 2018 | 08:44 AM
DGRF250's Avatar
DGRF250
Default 2018 Fatboy oil light
Riding my bike, oil light came on. Stopped, checked oil, oil fine. Started bike, oil light off. WTF
Old Feb 3, 2018 | 10:07 AM
Kojax's Avatar
Kojax
Smile
nothing to worry about
Old Feb 3, 2018 | 10:13 AM
Jackie Paper's Avatar
Jackie Paper
A 2018 should not be showing a oil light at idle much less ridding along. Now grant you, if it went off, what can you or a dealer do.
I would sure be having them at minimum write up a service statement on it.
I would not just want them tearing into it but a oil light if it is the real thing is a stop and trailer it kind of problem.
Old May 27, 2018 | 09:51 AM
rharbick's Avatar
rharbick
I've read somewhere in these forums that you should check your pump. Seems Harley oil pumps have a real problem with loosing pressure but not throwing a code. On a 2018 I would suspect improper assembly more than anything else.
Old Jul 11, 2022 | 07:39 PM
Gliden's Avatar
Gliden
Default Hd oil pumps
I read that the harley casting of the oem oil pump if you line the holes of the HD casted pump housing to the engine itself you'll see that they are slightly mismatched. Meaning that not 100% of the oil flow, flows because of the mismatch. The aftermarket pumps and housings are not made of casted junk metal and those holes are larger and line up perfectly and send 100% of the oil pressure thats suposed to flow to your motor.
Scot7449
Mar 19, 2015 10:49 AM
RobertV
Oil Archive (no new posts)
Jan 12, 2013 10:53 AM
Robert Strohl
May 8, 2012 12:15 PM
jmanjksu
Oct 11, 2010 10:27 AM
hog883
May 22, 2010 06:48 AM
