getting ready to do the 30/70 conversion
Old Aug 13, 2018 | 06:55 PM
Rocker B's Avatar
Rocker B
Originally Posted by weezl
really? I thought people were saying the factory spacing worked with the 260, so as long as the new pulley is the same location or slightly farther out it should still work...
I'm gonna run the .305 and see what happens.
The stock spacing will work with a 260 and a stock width pulley. I have a 260 on my Breakout with the 1" pulley, and it's fine. The problem with the 70T pulley is it's 1 1/8" wide, so if installed with the outside edge at about same location as stock, the belt is now able to move 1/8" closer to the tire. With the 5/16" spacer, it was ok when rolling forward because the belt tracks to the outside of the pulley, but when backing up the belt tracks to the inside and would rub the tire.
Old Aug 13, 2018 | 08:55 PM
weezl's Avatar
weezl
Ok gotcha! Makes perfect sense.
Yeah, so right now I'm 1/16 or so wider than stock, so I shouldn't have any issues with a 260, going forward, but it will likely rub if I drive around in reverse (not overly likely )
I don't mind a little bit of rubbing here and there, 99% of my mileage is forward.
If only I could figure out this shift light wiring, I would be able to out this damn bike back together!
New transmission pulley is on, inner primary is on, shift light wiring is run through the bars, just need to figure out where to hook it for signal
Bobber406
Sep 21, 2018 07:56 PM
BUTLERR1
Nov 2, 2013 06:04 PM
derekdrago
EVO
Sep 12, 2012 04:34 AM
t150vej
EVO
15
Aug 12, 2011 05:38 PM
dub976
Jul 22, 2009 05:38 PM
