Has anyone tried these? I want to get a set but my ignition switch is integrated into the coil housing on my 2016 Breakout! I would get this if I could get a housing or something similar to house the ignition swtich
I put a set of the Accel COP's and they burned my ECU. Spent 3k in having the dealer replace the whole harness for the bike, 2 ECU's and the ABS module. These electrical issues started happening 6 months after installing the COP's. The COP's were removed and problem solved. Do not recommend them.,
For an OEM to moderate built, naturally aspirated Harley.... there really are no gains to be made changing from OEM plugs, wires, or coil..... Plus you have to be careful not to use something that will not work with the ion-sensing of the Twin Cams...
So this would be a purely aesthetic modification for $200+... everyone has different taste, but I think they are way uglier than plugs & wires.... If you want to jazz up that area, get some bright colored, silicone plug wires and/or a custom coil cover, it'd be a lot cheaper...
Yeah, I'd pass..... just my 2 cents...
I have been using them for two years now on top of some E3 Diamond Fires with no issues as a matter of fact I got a little snap in the throttle going through 2nd, 3rd, and 4th gear
