Plug and play wire kit
Old Sep 29, 2018 | 06:40 AM
mxskater25's Avatar
mxskater25
3rd Gear
Default Plug and play wire kit
I’m swapping my handlebars on my softail slim to 12” mini apes. I’m pretty sure I can reuse the stock wiring and cables, but in the event I can’t, what is a good plug and play wire extension kit that doesn’t require cutting?
Part 2: What’s a good aftermarket clamp for ape hangers. Preferably one that has a set screw
thank you for your help, ps I did spend a day or two searching for answers before I posted. Thanks in advance.
Old Sep 29, 2018 | 07:43 AM
Roadie13's Avatar
Roadie13
NAMZ for the wire extensions. I've always bought the clamp if needed from the bar manufacturer.
Old Sep 29, 2018 | 07:45 AM
Iceman24's Avatar
Iceman24
Nice 1st post...make sure you hit the "New Member" section & do a proper intro.
First, have to ask, have you ever swapped bars and/or have the tools/talent/manual to work on bike?
Old Sep 29, 2018 | 07:47 AM
mxskater25's Avatar
mxskater25
3rd Gear
I’m pretty sure I’ve posted here before. I’ve never swapped the bars but yes I have the tools and know how to do it, I’ve already changed the exhaust, intake, grips clutch and clutch adjustments all by my big boy self.
I found this this but not sure if this includes everything from namz or if I have to piece it all together
https://namzcustomcycleproducts.com/...014-up-models/
Old Sep 29, 2018 | 09:23 AM
Chambeaux's Avatar
Chambeaux
Namz for the wiring. If you have TBW you may need purchase a separate connection for it.
Old Sep 29, 2018 | 10:04 AM
mxskater25's Avatar
mxskater25
3rd Gear
thanks, I’ll have to email them because I haven’t found a single kit looks like I’ll have to order each wire separately. Their website isn’t the best design
question do I have to remove the pins from the connectors or can I pull the connectors through the handlebars.
whiskeyfire
Oct 28, 2020 03:45 PM
brihvac
Sep 2, 2018 04:45 PM
RET_SCPO
Electrical/Lighting/Alarm
Feb 22, 2018 05:57 PM
lhgdale
2014-2024 Touring Models
Oct 14, 2015 09:09 AM
Trash Rat
Jan 28, 2009 05:55 PM
