Changing brake fluid
Old Oct 22, 2005 | 05:50 PM
softail 99's Avatar
softail 99
Default Changing brake fluid
Hi, I have a 99 heriage softail, Was wondering the best way to change brake fluid. What kind of tool do they use to remove the fill plugs on top of the forks. The chrome nuts. without damage to them. This will be my first time with the forks I think it uses dot 5. Anyone help thanks have 22,000 miles on the bike had it serviced once for the forks at least I think they changed fluid!
Old Oct 22, 2005 | 06:46 PM
HDF Tech's Avatar
HDF Tech
Default RE: Changing brake fluid
I dont know if you have a few words mixed up here, but the forks and brake fluid don't go in the same sentence. The nuts for fork oil can be removed with a large crescent wrench without damage to the chrome.
I still think there is a wire crossed here. You are trying to change the FORK oil?
If so , I suggest to get a manual before you damage something or yourself too.
Also check your manual for the proper DOT brake fluid for your bike as the wrong one will damage the system.(probably DOT 4)
Check here https://www.hdforums.com/m_88878/tm.htm
Old Oct 23, 2005 | 11:25 AM
softail 99's Avatar
softail 99
Yes I guess I screwed up here sorry about it. My mind was wondering about to many thing. I was asking about changing fork oil only. I have a manual from harley should I put bike on lift to extend forks is there spring presser when I remove filler nuts? So just a cresent wrench will do.Do I have to move handle bars to get at the filler nuts. Thanks again sorry about the mix up.
Ps I wasn't even drinkin! Rich
Old Oct 23, 2005 | 12:15 PM
HDF Tech's Avatar
HDF Tech
Softail shouldn't have much of any spring pressure behind the nut as long as it's up on a lift, just be carefull anyway. You should be able to get at the nuts without any trouble. It's close but not that close that you have to remove the bars.
Camaro2ssls3
Mar 25, 2017 10:06 PM
ADVNTR
2014-2024 Touring Models
25
Jan 17, 2017 07:37 AM
Don Lampert
Aug 29, 2016 07:35 PM
tom lipke
Jan 5, 2012 09:48 AM
Da Gumpmeister
Jan 27, 2010 10:06 AM
