Troubled 00 5 speed
Old Nov 3, 2018 | 06:42 PM
Lou'sUltra's Avatar
Lou'sUltra
Welcome from Ohio
Old Nov 3, 2018 | 06:47 PM
critter85's Avatar
critter85
Welcome to the Forum
Old Nov 3, 2018 | 07:35 PM
PDB17UltraRG's Avatar
PDB17UltraRG
Welcome to the Forum lots of great info here enjoy and learn or brush up a bit from Stuart Fl. Ride a Lot Ride Safe.
Old Nov 3, 2018 | 09:00 PM
the wild hog's Avatar
the wild hog
Welcome
Old Nov 3, 2018 | 10:33 PM
sloufoot's Avatar
sloufoot
Old Nov 4, 2018 | 12:59 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Don't think your making enough power to flex that shaft. I would first take a look at the vent and make sure it's not plugged.... Also depending on mileage could just be a worn seal.... Are you sure it's not the IPB seal?
Old Nov 5, 2018 | 06:25 AM
Raw power's Avatar
Raw power
Stage IV
I'm not sure of the strength of the main shaft, but it was right after the upgrade. Someone on you tube did the exact upgrades I did, with the same issue. He upgraded his mainshaft to an Andrew's performance shafts built for performance bikes to solve his problem. Seems like 100 hp is not enough power to bend or wear anything out. All seals except the one leaking. The seal behind the pulley has been replaced twice with only a couple hundred miles on it, then back primary seal went out, replaced it, now the seal in the main shaft behind the pulley is out. I don't know the milage on the trans, so, I'm thinking just rebuild it.
Old Nov 6, 2018 | 02:06 PM
Clammy's Avatar
Clammy
Reaper, my 2005 Night Train, has similar engine upgrades (98ci, gear drive cams, high comp, etc... ~100 hp / ~116 ft-lbs), with about 140,000 miles, since the build, and over 151,000 miles total on the bone stock transmission. The only time I had a trans leak (aside from the typical shift shaft seal leak) was when the inner primary bearing inner race, pressed onto the trans output shaft, walked inward and took out the seal. That happened about 4 years ago. I replaced the stock 2 piece bearing with a Baker one piece unit, and haven't had a drop spill out since.
Cheers!
Old Nov 6, 2018 | 03:16 PM
corliss@bakerdrivetrain.com's Avatar
If you are changing the main seal I would change the quad seal and the pulley spacer at the same time.
Raw power
Nov 3, 2018 12:15 PM
SCGamecock
Welcome Area Only
16
May 2, 2018 10:42 PM
sh3pilot
Welcome Area Only
Nov 9, 2012 01:51 PM
AMen
Oct 4, 2012 02:17 PM
jmadden
Welcome Area Only
21
Nov 30, 2007 07:53 AM
