2001 Heritage Softail Classic Speedometer not working
Old Nov 3, 2018 | 11:05 PM
GhostC6's Avatar
GhostC6
Default 2001 Heritage Softail Classic Speedometer not working
My speedometer is not working at all. It does nothing when I turn it to ignition or accessory or while driving it.
I removed the speed sensor and cleaned and reinstalled it and no change. I checked the back of the speedometer and it is clean and connected.
I would like to check where the speed sensor plugs into the other harness but need help or photos showing where that connection is from the sensor it runs up behind the oil tank but no idea from there. I need to find it even if I need to replace the sensor so if anyone can tell me or show me where that connects I would appreciate it very much.
Thanks in advance.
Old Nov 4, 2018 | 08:20 AM
Pothole914's Avatar
Pothole914
Check the fuse. That happened to me on my 08 Heritage. I was on a road trip somewhere in Indiana, after 3 hours checking everything else, the dealer finally checked the fuse and it was blown. New fuse, worked perfectly.
Old Nov 4, 2018 | 09:37 AM
PDB17UltraRG's Avatar
PDB17UltraRG
That a simple fit check your fuses.
Old Nov 4, 2018 | 12:58 PM
GhostC6's Avatar
GhostC6
Checked all the fuses under the seat and they are all good.
Old Nov 4, 2018 | 03:44 PM
Pothole914's Avatar
Pothole914
check them with a meter. It's not unusual for them to "appear" good and be blown. Seen it many times.
Old Nov 4, 2018 | 07:21 PM
the blob's Avatar
the blob
Check your charging system also.
Old Nov 5, 2018 | 03:45 PM
4 inch pistons's Avatar
4 inch pistons
It is a 15amp fuse that also works the turn signals. If you check you will find the turn signals are not working either.
Old Nov 5, 2018 | 09:56 PM
GhostC6's Avatar
GhostC6
My turn signals do not self cancel, I guess I need to replace the speed sensor, does anyone know where it plugs in, is it between the fender liner and fender in front of the rear tire? And can you get to it without removing the rear tire? Thanks to all of you.
Old Nov 6, 2018 | 08:14 AM
4 inch pistons
What I meant to say is that on my 01 Softail, I shorted a wire while changing the bars. The running lights, headlight, brake light all worked fine but nothing happened when I turned on the turn signals. Also the speedometer quit. I fixed the short, replaced the fuse and the speed O and signals worked fine. It is true that sometimes you cannot look at a fuse and tell if it is good or bad. But if your turn signals are blinking and the fuse box on your 01 Softail is the same as my 01 Softail, then I don't think it is the fuse. My next question would be does the odometer come on when you turn the switch on? That will verify if it is an electrical power issue for sure. Mine did not when the fuse was blown. On mine it is the fuse box under the seat. It was the 15amp fuse closest to the rear tire in the middle of the box if I remember correctly.
Old Nov 6, 2018 | 10:16 AM
GhostC6's Avatar
GhostC6
If I can I will upload a video or pic of what it does, my signals work but do not self cancel, the speedometer needle does not move with speed, when I turn the bike ignition on it jumps ever so slightly and I think the backlight comes on.
