Help - weird electrical fault
Old May 28, 2019 | 01:26 AM
Shellfish20's Avatar
Shellfish20
Default Help - weird electrical fault
Hi all, I need some help.
Riding home today and when I throttle off the bike stalls like the idle is set too low - starts again with a flick of the starter.
Also, at the same time, no speed shown on the dial, speedo has all the lights and normal displays, just a needle not moving.
I only mention both because they seemed to have come up at the same time, I can't see how they're related - but it might help diagnosis.
Before tonight I've had no problems at all - any ideas?
Cheers
Steve
Old May 28, 2019 | 02:20 AM
1of2's Avatar
1of2
"Moderator"
When the speedo does that it is usually the speed sensor that goes into the tranny. Pull that out and clean it off and usually everything goes back to normal. Not sure about the other problem.
Old May 28, 2019 | 03:23 AM
vonh12's Avatar
vonh12
Check for a code. That might answer your question.
Old May 28, 2019 | 06:20 AM
RANGER73's Avatar
RANGER73
Just throwing this out there. I went for a ride this weekend and after taking a rest stop the bike wouldn't start. All lights worked but they're all LED's.
I carry a jump pack and got her started. Road home about 60 miles. No Tach, or directionals.
Turns out my voltage regulator wasn't charging and I only had 8.4 volts when I got home.
Old Jun 7, 2019 | 04:14 PM
Shellfish20
RESOLVED.
Error code reported VSS high.
Pulled, cleaned and replace the Vehicle Speed Sensor, no change.
Replaced the sensor and all the problems have disappeared.
Thanks for the help guys.
Steve
Old Jun 7, 2019 | 09:58 PM
b bop n bob's Avatar
b bop n bob
Had the same problem, plus odometer doesn't register and turn sig auto-cancel didn't work. VSS $46 at the dealer. Guess that new Harley t-shirt will have to wait.LOL
RosevilleRiding
Jun 2, 2018 08:47 PM
08FXDC
Oct 1, 2012 07:03 PM
Turbo Turtle
Jan 1, 2012 10:57 PM
mhammer
Jun 30, 2009 08:59 PM
MR. SCOOTINN
Oct 9, 2007 04:58 PM
