2007 softail classic custom
Old Oct 7, 2019 | 08:34 PM
Kotagirl72's Avatar
Kotagirl72
Default 2007 softail classic custom
Been having some charging issues with the bike lately. I hooked up fault finder and found some shorts in the wiring in the taillights. Replaced the voltage regulator and it is still not charging. I have a short I believe in the run switch and planning on replacing the switch however I believe that the stator has failed. I did smell the primary oil and it doesn’t smell like burnt wires but when I take it for a short run the fins on the voltage regulator does not even get a little warm like they do on my 1200. Any thoughts and is this a good indication? I’ve checked and cleaned all grounds, battery and did ohms test. Also I’ve heard it’s not bad to replace the stator is this true?
Old Oct 8, 2019 | 12:02 PM
mmesa005's Avatar
mmesa005
There are some good troubleshooting tips here http://cycleelectricinc.com/
Plumbwader
Sep 23, 2017 08:00 AM
HAWGMAN
Oct 23, 2015 08:48 PM
HoggyMtnBreakdown
Sep 7, 2011 10:19 PM
Seaweed1929
Dec 4, 2009 08:32 PM
hawg50
Sep 17, 2007 08:44 AM
