I'm in the process of building a 117" Twin Cam Softail utilising most parts from a 2004 Fatboy donor bike. I bought a later 103" engine which has been the basis of a 117" build. Spec as follows:-
The builder has recommended the SE 58mm throttle body with 5.3 injectors, but I'm using the wiring loom from the 04 Fatboy which I believe is incompatible with that part. I see that S&S do a 58mm body for the 00-05 Twin Cam motor. I've also been offered a secondhand 55mm S&S body.
I need advice on whether the 55mm with 5.3 injectors will be sufficient or should I buy the 58mm. If the latter is the case, is the 66mm worth considering? Are there any other options I should consider? I'm in the UK so my choices are really limited to S&S and Harley products as I don't want to be sending parts back across the pond if I have issues. Confused!!!
Sorry no answer for you, but rather a question.
You didn't list larger jugs? If you've got a 103 with
a 4.375-inch stroke, you'll need a 4.125" bore to
get to 117CI. This will require cracking the cases to
machine for larger spigot size. Just wondering if you're
going with the Axtell or Harley jugs...
Thanks,
T.
Sorry, I I haven't listed the full build but just included the info I thought relevant to the question. I went with Harley jugs simply because I managed to pick a set up cheaply. Cases were machined and bottom end rebuilt with big lefty bearings both sides and a trued and welded crank.
Reason: Misspelled
I don't know anything more than what I read. I've seen 124's setup with a 58mm and the 5.3 injectors so you're 117 should be well fed with that. For the injection stuff id stay with harley.
...snip...
I'm leaning towards investing in a 58mm body unless anyone can give me an insight into how the 55mm will work with my setup. But do Harley produce a 58mm throttle body for use with the 00-05 Delphi system? If not then my choice is limited to the S&S part
