Bike won't start
Old Feb 26, 2020 | 01:15 PM
matte's Avatar
matte
Background. Bike is 2016 heritage. 150 miles on it. Original owner traded it in due to a surgery that left him unable to ride. Bought it before the winter and rode it home. Battery was likely dead from winter and not on the tender. And as someone asked, before the jump attempt, it was clicking when I attempted to start it. afterward is where it no longer was even sounding like it was engaging. Lights on with power, fuel pump starts, no signal from start button.
Bike is at the dealer. So far they know the ecm is not communicating. U0100 code. Plan is to hook up a new ecm and see if it turns over. Under warranty so should not be too much. Still appreciate the insight guys!
Old Feb 26, 2020 | 04:50 PM
Zerk's Avatar
Zerk
Originally Posted by shaggieshapiro
The first thing
The third thing I would do is to put a voltmeter to the battery and measure the voltage. (should be around 13.6V)
a
The bike is not running, so Jax it should be is 12.7. 12.3 isn't great, but I should think it might start or click.
put the charger on 10 amps, if you get clicking, and didn't before, battery is bad. Hopefully just a bad battery.
jump start with revving motor should get a click or more, but might not hear it. Jump pack would better.
I am guessing bad battery.
Old Feb 28, 2020 | 07:28 PM
matte's Avatar
matte
Well Harley’s been troubleshooting further. Looking like the ECM is not communicating with the bike. So we’re waiting for a new one to come in and the dealer to update the info. On a positive note, corporate is replacing it without using the extended warranty due to the low miles and age. So no copay. Still winter in Michigan so no rush. Sadly missed riding the one good February day we had though.
Old Mar 10, 2020 | 01:24 PM
Bluraven's Avatar
Bluraven
Was the issue found?
Old Apr 22, 2020 | 08:42 AM
Bluraven's Avatar
Bluraven
Is the Dealing still troubleshooting the issue?
Not following up with posting a resolution to an issue that you're asked for help with is bad forum etiquette.
Old Apr 24, 2020 | 11:32 PM
matte's Avatar
matte
forgot about the thread. Ecm was hosed as well as the abs module. All fixed and replaced.
Old Apr 25, 2020 | 07:05 AM
Bluraven's Avatar
Bluraven
Thanks for the posting the fix.
Sounds like you might have just had a dead battery but when you tried to jump start it using your Subaru the ECM and ABS module got fried.
My bet is perhaps the ABS module was unrelated but who really knows when it comes to electronics.
You did state that when you connected the bike to the Subaru the Subaru horn was sounding and there were sparks off the battery.
As you noted neither is a good sign,
I don't think you stated whether or not the Subaru engine was running when you connected to the bike but I would think that would probably be the case.
Connecting a 12v vehicle battery to a bike's 12v system shouldn't hurt anything however if the vehicle is running the bike's electronic system just can't handle that.
Anyway, I highly recommend that all riders invest in a micro jump starter.
There are quite a few that are under $50 and most can be used for other things such as jumping other vehicles and charging things like cell phones and laptops.
I have an Antigravities XP-10 with a hard wired connection to my bike.
The XP-10 stays in my saddle bag and if/when needed I simple connect it to the dedicated pigtail and jump start the bike.
Note though don't jump start a bike using the battery tender connection.
That wire can't handle the amp draw and will fry (trust me I know this first hand )
Anyway again that's to the OP for posting the fix.
Ride safe all.
Old Sep 13, 2021 | 05:35 PM
RSidhu's Avatar
RSidhu
Matte. I have different issue but some of your symptoms are the same as mine. My case I had these problems after I installed my custom tune post battery replacement. Check the thread VINERR ECM no response. Not sure if you have any custom tunes installed.
Old Sep 13, 2021 | 05:39 PM
Jackie Paper's Avatar
Jackie Paper
Might want to check dates on deep searches before posting.
Steve Bokowski
Electrical/Lighting/Alarm
Jul 2, 2018 09:55 PM
prostreetdon
May 22, 2013 08:36 AM
riiano
Jan 21, 2013 02:46 PM
Schaub85
Jul 3, 2010 04:53 PM
prostreetdon
Jun 8, 2010 11:59 AM
