Won't start
Old Apr 26, 2020 | 08:38 PM
19harley88's Avatar
19harley88
Stage II
Default Won't start
2003 heritage. Engine turns over can hear fuel pump and smell raw gas. Backfired through pipes. Only 23k on it. Any ideas anyone? Could timing have jumped out?
Old Apr 26, 2020 | 09:06 PM
hattitude's Avatar
hattitude
Gas engines run on spark, gas, and compression... just start systematically going through the possibilities. Start with the simple stuff...
Was it running well and then just all of a sudden it won't start...???
There are several things that would give you a clue where to start looking...
Checked for codes....???
Any recent service/repair/mods...???
Unlikely that once a cam chest is properly assembled, the gears would just jump out of proper timing, unless of course, something broke in the cam chest.... Have you ever checked/changed out the spring cam tensioners....???
Are you getting spark....? No spark could be caused by many things on an EFI/ECM bike. Could be something simple like a bad ground or connection, all the way up to a bad ECM...
If there is spark, compression or leak down test...???
If there is spark, compression, and it's just an over fueling issue, check the fuel injectors...???
Good luck.... with your diagnosis... be thorough, be patient, and try to look for clues that can lead you to the problem....
Old Apr 26, 2020 | 09:18 PM
Zerk's Avatar
Zerk
As said, check spark. Same drill, pretty much any engine that won't start. I really doubt your timing is off, that is so far down the list of things to look at when trouble shooting. Unless you have bike apart and didn't align the dots.
Old Apr 27, 2020 | 03:46 PM
19harley88's Avatar
19harley88
Stage II
Default Won't start.
Was sitting for about a month. Batt was down. Charged it. Checked fuses all ok. Used an old lawn mower plug to test only got one spark then dead. Going to get a multi meter and check coil pack
was hard to start a couple of times, but thought it was that it had been sitting. Finally started and ran fine. But now nothing. Checked for codes but none came up
Old Apr 27, 2020 | 05:43 PM
Zerk's Avatar
Zerk
I check spark by taking plugs out, and with them on the wire, have them touching metal. Its not perfect, and they do make tools to test the strength of the spark.
How do you check fuses without a meter?
I had a bad coil, that ohmed fine.
But if it is turning over,spark and fuel are the thigns to check. Next will be to check fuel pressure. Though back firing can be to much fuel, so I'd start with spark.
Old Apr 28, 2020 | 10:43 PM
hattitude's Avatar
hattitude
When a battery gets discharged, and then sits in a state of discharge, it can kill the battery... your problems COULD be caused by a bad battery...
Make sure to load test the battery. A bad battery will sometimes take and show a full charge. You'll think it's good to go, until a load is applied.... a starter motor is a significant load
The load test will either rule out the battery, then you can continue your other diagnostic checks..... or the load test will tell you the battery needs to be replaced....
Old Apr 30, 2020 | 06:49 PM
Madison Bill's Avatar
Madison Bill
Did you accidentally switch the plug wires on your coil?
gwakehoff
General Topics/Tech Tips
Aug 8, 2018 09:26 AM
Robby999us
Jun 28, 2017 10:25 PM
Robby999us
Jun 26, 2017 06:38 PM
springer2003
May 12, 2008 03:04 AM
leohd
Apr 3, 2008 10:43 PM
