Great Gas mileage
Old Jul 27, 2007 | 11:50 PM
clutchglass's Avatar
clutchglass
Default RE: Great Gas mileage
Bow,
You must have went practicaly right past my place. I'm just off the 58 12 miles west of 395. Guess that cuts out the "hi elevation" theory. While I do believe some folks stretch their gas milage claims a bit...and I'm sure that dealer sticker said 35mpg, I have to believe I could be getting better gas milage. Out on a roadtrip I can get 35mpg if I go the speed limit, but here in Cali...that's almost downright dangerous.
None the less, my put runs GREAT, and gas milage probably won't get any better with the Andrews 21G geared cams I want to put in. The only thing left for me to try (gas mileage wise) is to get my power commander dynoed in after I do the cam install, but with as good as it runs now...I'm not thinking the map I got when I bought it at fuelmottousa could be off by much (if any).
2006 Heritage Softail Classic
PCIIIUSB, Python3 slip ons, SE Stage1 Air intake running a K&N oiled filter, Billetcool Oil Cooler,
Harley aftermarket self tensioing primary chain tensioner
Old Jul 28, 2007 | 12:43 PM
Oldtimer of NM's Avatar
Oldtimer of NM
As best I can remember, the official EPA highway rating for big twins is around 53 - 54 mpg, and it is possible to really do that or even better it. Chances are that your bike is not running exessively lean. A very lean mixture won't produce as much power. So, a very lean mix will cause you to have to open the throttle more and downshift more, so you end up actually using more gas than with a proper mixture.
jpooch00
2014-2024 Touring Models
72
Aug 11, 2015 07:59 PM
DavidStiebel
Aug 23, 2014 03:50 PM
stmpulr
Exhaust System Topics
Mar 24, 2013 03:17 PM
Big Tom
Apr 7, 2008 09:01 PM
madden23
May 26, 2007 04:56 PM
