05 Night Train runs rough
Old Sep 28, 2020 | 05:46 PM
brettpobastad's Avatar
brettpobastad
2nd Gear
Default 05 Night Train runs rough
I washed my 2005 FXTBI Night Train a couple of weeks ago and I still can't get it to run smoothly. It fires up right away and idles ok at first. After a few minutes, it stays idling but starts huffing through the air cleaner/intake every so often, and when you twist the throttle, it falls on its face and almost wants to cut out. Sometimes you can see a quick blast of flame out of the exhaust.
As stated above... this started happening the first time I fired it up a couple days after I washed. Usually after I wash the bike, I fire it up right away and take it for a spin to blow off the excess water. Didn't do that this time because my shoulder is injured and I can't ride.
Here's what I've tried:
All the connections under the seat were dry to the eye, but I checked them all anyway. Cleaned with contact cleaner and applied dielectric grease where applicable, including to plug wire ends at the plugs and coil.
Spark plugs looked good. Changed them anyway and changed them back.
Cleaned and dried the air filter.
Tried to clean the sensor in the hole in the carb inlet with the proper MAF cleaner. (got this idea from my brother)
Added fresh gas and some Seafoam (got this idea from a shop)
Any ideas on what to check or what to try before I really get into it or take it to the shop? It was running great before I washed it. The guy at the shop that recommended trying the Seafood said it might be an intake gasket leak.
506nighttrain
May 19, 2017 08:02 AM
0311Train
Sep 13, 2015 01:59 PM
Bobbiperry
Apr 10, 2012 06:15 AM
Carlos2010
Sep 18, 2010 09:06 AM
hfdsod
Aug 31, 2008 06:37 PM
