160 Rear on an 05 NT?
Old Jul 28, 2007 | 08:33 PM
imboden's Avatar
imboden
Default 160 Rear on an 05 NT?
This guy I buy my synthetic oil from was tellin me he thought a 160 would fit in my stock swingarm, does that sound right? He had an avon venom 160 rear we held up to see and it looked like it would clear. Anybody do it? Remember I've gotta 2005 NT...thanks fellas.
Old Jul 28, 2007 | 08:40 PM
Peekon's Avatar
Peekon
Default RE: 160 Rear on an 05 NT?
i have a metzler 160 on my 2005 fatboy. i was told the metzeler was the only tire and it had to be on an 18" rim. Mine fits great but there is not any room left
Old Jul 28, 2007 | 08:42 PM
imboden's Avatar
imboden
huh, just bought an avon venom front, wonder if I can mix tread like that. I was always told you want the same brand on the front and back
Old Jul 28, 2007 | 08:46 PM
Peekon's Avatar
Peekon
don't know if mixing would cause a problem just think it might look funny . u can always sell the new front on ebay
Old Jul 30, 2007 | 12:46 AM
ChromeJunkie's Avatar
ChromeJunkie
If you are running stock wheels, a 160 wont fit. Minimum wheel width for a 160 is a 3.5 in wheel. I am running two different brands of tires and have no problem with them. Dunlop Elite 3 on front and Avon Venom X on the rear. Tread pattern isvery similarand it handles great.
Old Jul 30, 2007 | 12:59 AM
1CrazyTrain's Avatar
1CrazyTrain
ORIGINAL: imboden
Yes sir, with proper spaceing and a wheel that has a 4.5 or 5.5 width for a 160 tire.
Old Jul 30, 2007 | 08:37 AM
XXXRacing's Avatar
XXXRacing
Check out the Avon 150 V rated tire, it is actually 158mm (the H rated isnot as wide)and it barely fit on my 05 NT. Filled out the fender nicely.
Old Jul 31, 2007 | 12:41 PM
imboden's Avatar
imboden
hey man good to see you still in the softail section now and then. what in the hell does H rated mean? I'll go that route if it fits....thanks
ORIGINAL: XXXRacing
Old Jul 31, 2007 | 03:34 PM
XXXRacing's Avatar
XXXRacing
H and V are the speed ratings. V has a higher speed rating than H.
Old Jul 31, 2007 | 05:23 PM
back again's Avatar
back again
Imboden Here is apicof my 05 Train I was talking to you about.This is a 160/16 Metzler on a stock 05 Night Train wheel. The tire fits fine on the wheel and the spacing is better than it was stock. Spread the frame rails a little with a porta power. Have a little better than 1/8th" on each side between the frame rail and tire. Ride 2 up alot and this set up does not rub at all. Changed the stock 150 tire twice and both of them rubbed the ridge thats on the harley tire. I used 1/8" fender washers between the frame rail and fender to move the fender to the left and center it better.
[IMG]local://upfiles/2297/77B07AB24FD443FCA50EAC2ECF82CC20.jpg[/IMG]
[IMG]local://upfiles/2297/8D529B01507A4A5FAF2EA738790B4477.jpg[/IMG]
