Cam Timing
Old Nov 23, 2020 | 08:54 AM
gdishman's Avatar
gdishman
Default Cam Timing
What would be the symptoms of the front cam being out of time. Bike idles rough, But runs ok. The front cylinder is running rich by O2 sensor reading.
Old Dec 24, 2020 | 01:56 AM
Charlie Day's Avatar
Charlie Day
so I'm gathering you have changed your cams?
Old Dec 24, 2020 | 05:46 AM
gdishman's Avatar
gdishman
Yes took all apart again and found the front cam one tooth off.
Old Dec 24, 2020 | 05:53 AM
Softailwayno's Avatar
Softailwayno
6th Gear
Sorted it ?
Old Dec 25, 2020 | 06:30 AM
Madison Bill's Avatar
Madison Bill
Do you mean like this?
Old Dec 25, 2020 | 07:52 AM
Charlie Day
No, with that large sprocket misaligned to the crank it would make both cams out of time. He was referring to the right cam (front cam) misaligned to the left cam being the rear cylinder cam.
Old Dec 25, 2020 | 08:17 AM
gdishman's Avatar
gdishman
You are right Charlie Day. The front cam was off one tooth. The compression of both cylinder was very close to being the same. The bike really didn't run bad. But had a radical idle.
Old Dec 25, 2020 | 09:43 AM
Baird's Avatar
Baird
Just curious, was the front cam advanced or retarded WRT rear?
liska holmes
Sep 27, 2020 09:36 PM
balesarich
May 29, 2017 08:47 PM
mark fullner
Sep 2, 2015 11:07 AM
evil1968
Exhaust System Topics
Nov 1, 2009 09:21 AM
rking2000
May 16, 2008 11:50 AM
