Solid mounts to Rubber mounts
Old Dec 9, 2020 | 02:09 PM
Infamous_ride's Avatar
Infamous_ride
6th Gear
Originally Posted by Clammy
If you have anything higher than 10" mini-apes, polyurethane or solid bushings are a necessity. Otherwise, you get a LOT of slop in the bars. This has been my experience running 10" minis to 14" to the 16" apes I currently have.
Cheers!
I'm running 14" bars, are you saying not a good idea to run rubber bushings ?
Old Dec 9, 2020 | 02:19 PM
Clammy's Avatar
Clammy
Originally Posted by MCSarge
That's probably why, not a fan of apes on bikes. Much prefer drag bars.
Yeah, for drag bars, the rubber bushings are just fine.
Cheers!
Old Dec 9, 2020 | 02:20 PM
Clammy's Avatar
Clammy
When I went from the 10" minis to the 14" apes, I had to change the bushings to poly. With the rubber ones, I could move the bars back and forth a couple of inches each way, and it made for very squirerly handling.
Even with the 10"ers, there was noticeable movement.
Just out of curiosity, do the 14" bars put your hands above your shoulders when you're in riding position? If they do, that's the reason for the numbness, and no changes to the bushings will make a difference.
Cheers!
Old Dec 9, 2020 | 04:21 PM
NoRegerts's Avatar
NoRegerts
Bad idea with bars that tall. I have 14s and I'm running solid bushings. My bars don't buzz and my mirrors reflect behind me well. Seems backwards to me, but I feel like the bars are smoother now than the worn rubber ones were. But different engine and different front end on my bike. Not sure how big that plays into it.
Old Dec 9, 2020 | 05:52 PM
Infamous_ride
6th Gear
[QUOTE=Clammy;19588821]When I went from the 10" minis to the 14" apes, I had to change the bushings to poly. With the rubber ones, I could move the bars back and forth a couple of inches each way, and it made for very squirerly handling.
Cheers!
[/QUOTE
Yes, about in inch above shoulders. I belive I have poly bushings now. I'll try some different grips, the ones I have have zero rubber on them.
Old Dec 9, 2020 | 07:15 PM
Clammy's Avatar
Clammy
[QUOTE=Infamous_ride;19589295]
Cheers!
[/QUOTE
Ah, ok. The reason you're getting the numbness is that you're losing blood flow to your hands. The only solutions are go to lower bars, get a taller seat, or drop and shake out your hands occasionally while riding.
Cheers!
Tnbrit
Apr 12, 2019 08:52 AM
Johnnyh14
Apr 8, 2015 01:36 PM
alucard9899
Oct 4, 2013 07:25 AM
TxMoores
Apr 14, 2005 12:47 AM
