Power Vision instead of Power Commander. The PowerVision has an option to leave
the screen connected and perhaps attached to the handlebar so you can show different
guages on it while you ride. MasterTune is also an option.
I run a "flat" seat pan, made possible by relocating the ECM from the fender to the BCM area
in front of the rear wheel splashguard along with a smaller EarthX LiFePO4 battery.
I also use MasterTune to flash the ECM.
Thanks, but I already run the PC V. Just offering a suggestion for more room under the seat by purchasing the deeper pan from DynoJet. It worked well for me, and I have a lot under my seat. Not a fan of the LiFePO4 batts just yet, read to many premature failures and problems.
