Fork Rebuild Decisions
Old Apr 11, 2021 | 08:57 PM
Construct's Avatar
Construct
Default Fork Rebuild Decisions
I'm at a crossroads right now. Last time my FLSTF forks were changed of fluid was around 8 or 9 years ago.
Springs are sacked some now and need to be swapped out as well as fluid change. I picked up some cartridge emulators about a year ago and they sit in a box in my garage.
Some new HD progressive springs came in a month ago and are sitting.
Here's my issue, I modified the factory fork rods back then by welding up the bleed holes and then re-drilling them with smaller holes to help reduce the top out, which it did greatly.
The cartridge emulators require a stock set of rods to be drilled out quite a bit and even add more holes. (this part scares me as I know it weakens those rods with all those holes.)
If I just replace the oil and install the new springs, I'll get the ride that was good for my riding style.
I don't know how much better the cartridge emulators would work as I know of no one who used them.
To make it worse, my front end on the FLSTF is not stock and looks like an FLCH type of front end trim which makes it a bitch to make anykind of adjustment on them.
Anyone use fork emulators before and can comment would be great in getting my head around this work.
Old Apr 12, 2021 | 05:20 PM
misfitJason's Avatar
misfitJason
I have both setups on my two bikes. My Softail just has progressive springs and heavier oil. My Dyna has ricor intimidators, preload adjusters and heavier oil. I prefer just the springs and heavier oil.
Old Apr 12, 2021 | 05:48 PM
86glider's Avatar
86glider
I installed the progressive cartridges in mine.Firmer ride but no more bottoming out and tracks straight.Love them.
Old Apr 13, 2021 | 11:23 AM
Construct's Avatar
Construct
Did you modify your rods per their recomendations?
Old Apr 13, 2021 | 01:01 PM
86glider's Avatar
86glider
Only thing other than the cartridges were the bushings and new seals.Didn’t see any recommendations.Oops, were there?
Old Apr 13, 2021 | 05:55 PM
Construct's Avatar
Construct
For the emulators I received, they said to re drill anddtional bleed holes in the fork rods in multiple locations.
The damn thing looks like swiss cheese if done to they're spec.
Old Apr 13, 2021 | 05:56 PM
Construct's Avatar
Construct
Wait, you installed cartridges.
That option doesn't exist for me with my forks on an FLSTF, thus the emulators.
Old Apr 14, 2021 | 02:08 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Another way to firm up a set of progressives is too make the plug a 1/2"longer than suggested.. W/20w oil I love the feel in my Fatboy.. Sorry cannot offer advice on the emulators....
Old Apr 14, 2021 | 04:05 PM
60Gunner's Avatar
60Gunner
These Ricor Intiminators are the best thing you could do for your front suspension. 'Nuff said...
Allfields
Dec 27, 2020 10:50 AM
REW13
13
Sep 1, 2017 05:18 PM
Newellhole
Jun 16, 2015 09:32 AM
SURFOR Chop
Mar 15, 2011 08:20 AM
sporty2003
Sep 2, 2008 03:08 PM
