Using throttle lock
Old May 20, 2021 | 12:04 PM
RANGER73's Avatar
RANGER73
There's a lever you can attach to the **** or wheel.
A quick push with your thumb is all it takes.
There's also a grip lock. It holds your throttle open and rests against the brake lever
rotates back when you apply the brake.
Old May 20, 2021 | 12:06 PM
RK_Classic's Avatar
RK_Classic
Originally Posted by 04FXDI
Someone I know use to use it all the time, but found himself in a situation where he had to clutch and brake hard, motor revved to the point where he thought it was going to blow up, he won't use it anymore. I make one trip a year that requires highway, and I've set it for around 60/65 mph, sit in the right lane and lean back against the GF, not the safest thing to do I know. I don't use it very often, rarely if at all.
Had one on my sporty and used it commuting to work, I would get it thumb tight only, that would allow me to twist the throated forward to get off the gas, it took me a few times to get use to it.
rk classic.
Old May 20, 2021 | 12:33 PM
cocky's Avatar
cocky
I have used the leaver that attatches to the star on several bikes. Works great and it's cheap.
Old May 20, 2021 | 01:23 PM
UncleSoftail62's Avatar
UncleSoftail62
Ill check it out thanks!
Old May 20, 2021 | 01:32 PM
brakeless's Avatar
brakeless
My first thought when reading this is "Are you for real?" So, how old are you? Is this your 1st motorcycle? Didn't get an owners manual I'm guessing? I just find this hard to believe. Who'd you buy this bike from? Find the kill switch yet?
Old May 20, 2021 | 01:53 PM
04FXDI's Avatar
04FXDI
Girlfriend
Originally Posted by UncleSoftail62
Thanks, GF?
Old May 20, 2021 | 01:56 PM
04FXDI's Avatar
04FXDI
Yea I don't doubt that it works like I said I've used it. But he wasn't cruising the backroads, he was hammering down the highway, the outcome was not pleasant.
Originally Posted by RK_Classic
Had one on my sporty and used it commuting to work, I would get it thumb tight only, that would allow me to twist the throated forward to get off the gas, it took me a few times to get use to it.rk classic.
Old May 20, 2021 | 01:59 PM
RK_Classic's Avatar
RK_Classic
Legitimate question, Relax!
rk classic.
Old May 22, 2021 | 06:40 AM
back again's Avatar
back again
Originally Posted by Uncle Peepers
I bought a used 2014 Heritage Classic not long ago, and I was surprised to find they still had that thing. I always thought they were dangerous.
There are dangerous in the wrong hands, Similar to a gun.
Old May 22, 2021 | 06:52 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
A couple of lines from an Owner's manual:
To reduce rider fatigue on long trips, a spring loaded throttle friction adjustment screw is located at the bottom of the throttle grip clamp on non-cruise equipped models.
Warning: Do not tighten throttle friction adjustment screw to the point where the engine will not return to idle automatically.
