How Do You Tie Her Down?
Old Sep 8, 2021 | 09:41 AM
Shelstin's Avatar
Shelstin
Default How Do You Tie Her Down?
I need to buy another trailer, but for the time being, I have a small single axle, single bike trailer I pull occasionally. I spent all afternoon yesterday pulling, checking, and re-packing bearings and installing Bearing Buddies. I put on two new 8 ply trailer tires and a spare a few months ago after having two blowouts on a 400 mile trip. Obviously I don't trailer much. We can have another convo on using a 4 ply car tire and being a dumb *** and not checking for dry rot on another thread.
Since I was riding dirt bikes 4 decades ago, I have always tied to the handle bars. I currently don't have an option to get some of the cool strapless systems. Eventually that will be a probability when trailer prices drop.
I would like to see some options with ratcheted tie downs, other than using the handle bars. I really don't like compressing the shocks, or tweaking the handle bars. Pics if ya got 'em. Both of my bikes have front crash bars.
Old Sep 8, 2021 | 09:50 AM
Super Glidester's Avatar
Super Glidester
Spread eagle with a ball gag to a 4 poster...
Old Sep 8, 2021 | 09:52 AM
MCSarge's Avatar
MCSarge
I have a small 4x8 trailer for emergencies that has a wheel chock mounted in the front. For Softails I usually put the front tire in the chock and use soft wraps to go around the triple tree on each side to each side of the trailer. I also tie the front tire into the chock to keep it from backing out and use a strap wrapped around the back tire to each side of the trailer to keep it from moving side to side if it hits a big bump. I hauled a Sportster project bike from Louisiana to Michigan that way and never had an issue.
For touring bikes I do the same thing but I use the soft wraps around the crash bar since I have an RG and can't wrap around the forks.
Old Sep 8, 2021 | 11:38 AM
Architect's Avatar
Architect
This, wrap the straps around the lower legs above the fender bolt lugs. Super sturdy, but lets the suspension move with the road. I always put rear straps from the frame down to the truck, good insurance if one in the front breaks. Soft cover on the straps to avoid any unwanted scratches.
Old Sep 8, 2021 | 12:47 PM
Bone Doc's Avatar
Bone Doc
You and I think alike. I was going to post something crude when I read the title. Then I lost it after reading your post. You win.
Old Sep 8, 2021 | 05:20 PM
Shelstin's Avatar
Shelstin
Architect, I will see how that looks for me.
Bone Doc, I was hoping that the thread might draw some interest that way!
Old Sep 8, 2021 | 05:31 PM
WP50's Avatar
WP50
You can do it all with straps if you really have too.
A chock of some kind makes things a lot easier and can be found very reasonably priced as a rule.
The way Architect showed is how I do it
Soft ties and good straps are the way to go
WP
Old Sep 8, 2021 | 05:38 PM
TriGeezer's Avatar
TriGeezer
Old Sep 8, 2021 | 06:41 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A wheel chock
Frame mounted brackets on the steering neck.
High quality ratchet straps, with a safety latch at the connection points (they will keep the strap from becoming unhooked if they go slack momentarily).
Ratchet Straps Ratchet Straps
Tie Down Bracket Tie Down Bracket
Old Sep 8, 2021 | 08:33 PM
back again's Avatar
back again
[QUOTE=Architect;20168552]This, wrap the straps around the lower legs above the fender bolt lugs. Super sturdy, but lets the suspension move with the road. I always put rear straps from the frame down to the truck, good insurance if one in the front breaks. Soft cover on the straps to avoid any unwanted scratches.
this is the only way to go. Let the bikes suspension work freely. Bottom of the shocks on Dynas and Touring bikes,and swingarm on Softail s in the rear.
