Breakout power issues
Old Feb 28, 2022 | 10:46 AM
matte's Avatar
matte
Default Breakout power issues
Hi all. I’m having trouble with my breakout and figured I’d check here for some help. To start, I rode the bike a week ago with no issues. I’m gonna separate what I’ve done to make it easier for others to troubleshoot.
i went to turn on the bike and had headlights and tail light only. No response to the speedometer, hand controls, or fuel pump. No signals or even flashing lights when I move the bike without the fob. Fuses are all fine with none blown.
We had a cold week in Texas, and I think it may have impacted the lithium battery. When attempting to charge it, the charger showed an error that the battery has fully discharged.
bought a new battery and still have the same lights with no other response.
I’m thinking the ECM is shot. I will pull that next to check for corrosion.
any other thoughts on how to troubleshoot this?
Old Feb 28, 2022 | 08:42 PM
DrPlastic's Avatar
DrPlastic
Does the bike have the H-D security system installed?
Old Mar 1, 2022 | 06:32 AM
greybeard122's Avatar
greybeard122
Don't know what year your bike is, but check for corrosion at the ignition switch.
Old Mar 1, 2022 | 07:47 AM
matte's Avatar
matte
Bike is a 2015.. I’ll check the ignition switch for sure tonight.
there is something drawing power because I hear a click out an electrical current sound every ten seconds when the side switch is turned off.
Last night, I pulled the main fuse to allow the battery to charge. Put it in this morning and with the key fob near, I again get headlights and tail lights. Also when I turn it off, the rear lights will flash for the security system (not the front).
so it appears everything in the front harness appear to be not functional.
Old Mar 1, 2022 | 08:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What model bike?
Old Mar 1, 2022 | 08:06 AM
Sparky357's Avatar
Sparky357
Have you added any new electrical accessories to the bike?
Old Mar 1, 2022 | 09:40 AM
matte's Avatar
matte
Nope not in line. . I added front air shocks, but they’re hard lined to the battery. Removed the connection just in case and the issue persists. Changed the bars, but nothing pinched and has run fine for at least a few weeks since.
Old Mar 1, 2022 | 09:41 AM
Cap77's Avatar
Cap77
What model bike?
in the thread title, Dan
a Breakout
..L.T.A.
Old Mar 1, 2022 | 12:29 PM
Sparky357's Avatar
Sparky357
Where did you ground the compressor?
Old Mar 1, 2022 | 02:05 PM
matte's Avatar
matte
The compressor is wired straight to the battery. Main power has a fuse, but no other wires to ground. That actually runs fine.
