Lowering Softail questions
Old Apr 20, 2022 | 09:29 PM
RANGER73's Avatar
RANGER73
Same amount, you can tell by the distance from the rim to the strut.
But it'll go lower, still have rebound, but it'll scrape the splash guard.
Old Apr 22, 2022 | 08:59 PM
ChromeJunkie's Avatar
ChromeJunkie
I also wouldn’t recommend lowering it. I lowered my Heritage an inch and it rode like a tank and the handling was horrible. I raised it back to stock height soon after lowering it. That was an expensive experiment.
Old Apr 23, 2022 | 04:43 AM
Madison Bill's Avatar
Madison Bill
I lowered my Deluxe 2" in the rear and put an 18" in the rear and a 21" in front. No handling problems at all on my bike. From what I understand the OEM fender will fit no problem but I changed my front fender to a wrapped one and lowered it so I didn't have the dirt bike look.
Old Apr 23, 2022 | 09:14 AM
bulldog1776's Avatar
bulldog1776
Very nice bike.
How much did you lower the front with the 21?
Old Apr 23, 2022 | 06:02 PM
Madison Bill
Absolutely Zero.
Old Apr 23, 2022 | 06:40 PM
bulldog1776
Absolutely Zero.
Ok, so in the above picture that is 2" drop in the back and stock height in the front?
Old Apr 24, 2022 | 04:46 AM
Madison Bill
That is correct. Stock height with a 21" wheel.
Old Apr 24, 2022 | 05:47 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by RANGER73
I don't have any "before" pictures. But I was able to look right over the tire between the fender before.
I went from this, and this is lowered with the lowering shock extensions. It was a terrible ride
To this
That's nice.....
I take it, it's a Softail Custom...
I converted mine a little too a Custom front end with a Wide Glide fender.. I believe the Customs are 2" over the Heritage and Fatboy..
Looks great though and think the Sinister blue is one of the best colors they ever came out with.. Again nice job..
Old Apr 24, 2022 | 06:06 AM
98hotrodfatboy
I'm planning on running 21/16 wheels on my 1997 heritage classic.
I bought a burly front and rear lowering kit for it.
Burly lowering kit
I believe it is adjustable. I'm a big guy and I dont want to rub my tires. Trying to figure out how much I should drop it front and rear?
And also I think I need fender risers for a 21 up front, right?
Thanks guys
Not sure that the rear lowering kit will suffice with stock shocks if you're a big guy.. Guaranteed to rub the tire.. You would be better off with getting the proper shock to lower but still support your weight.. By going to a 21 in the front you will pick up a minimum of 1" in ride height so lowering 2" will put it to 1" under stock height to the top of the triple trees... I found a wide glide fender on flea Bay to replace the Fatboy fender.. The paint was a very close match, you have to look closely to see the difference.. I got lucky ..
Old Apr 24, 2022 | 08:55 AM
Bone Doc's Avatar
Bone Doc
The Progressive 422s with or without RAP will do just that. They allow you to drop the rear up to 2" while still maintaining ride quality.
