05 night train efi map sensor circuit
Old May 26, 2022 | 05:29 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Originally Posted by Throttleout
No bulbs out, but I think the security system was tripped when it was rollbacked home, because now it won’t even turn over, tried using key fob button, didn’t make a difference, even disconnected the battery for 10 minutes, re connected it same issue, turn signals flash side to side and no crank 🤬
You have 12.6 volts DC on battery? If so.
Battery in FOD. Turn key to left for just lights and put the code in using signal light buttons.
Mines set all ones. If you use all nines, you are going to be a while.
Old May 29, 2022 | 11:56 AM
Throttleout's Avatar
Throttleout
Help! I can’t get security system to turn off after bike was rollbacked home, tried the key on-off-on-off-on, left blinker 3x , right blinker 1x …. Nothing 🤬
Old May 29, 2022 | 12:40 PM
Jackie Paper
Give it back to the owner.
Old May 29, 2022 | 12:52 PM
Throttleout
I am the owner, just won’t come out of lock mode, battery in bike is new 12.8 volts, checked key fob battery, that’s 2.9 volts, tried the method with key fob, and the method without it, won’t go into code enter mode
Old May 29, 2022 | 02:09 PM
Throttleout
Well at least I got a beautiful piece of garage art, I didn’t want to ride it anyway, weather sucks, it’s like 80 degrees and sunny
Old May 29, 2022 | 02:21 PM
Ed Ramberger's Avatar
Ed Ramberger
1) put a new battery in the fob.
2) hold fob next to left handlebar and hold button. Could be up to 2 minutes until security responds. Hold don’t release.
3) if you don’t have a new fob battery or one you can swap from another fob or anything that uses the same try #2 and hope for the best
Old May 29, 2022 | 03:07 PM
Throttleout
Went back out to bike, held fob button, lights flashed once as soon as I hit button, held it down for about a minute, released it and punched it 2x quickly, lights flashed 2x and then fired right up, now to try to figure out why it left me stranded last time, but for now just the sound of it starting made my day😁
Throttleout
Welcome Area Only
18
May 29, 2022 01:55 PM
rawbo
Engine Mechanical Topics
Feb 19, 2018 05:58 AM
Roadkingfatboy
May 18, 2010 09:53 AM
augiedog
Sep 6, 2008 09:42 AM
88gator
Jan 30, 2008 11:53 AM
