07 engines and heat
I have some concerns with my 07 Nightrain (stock) and wondering if you could have some advices.
One day (outside temp 90°) I rode my NT for a 1hr ride, in the countryside, then a bit of town (10 minutes). I have put some gas and when i wanted to leave the engine stalled in first gear. Tried to fire her up but couldn't right away. So I have waited 5 minutes, then she started correctly. The only thing I felt wrong was that the engine was very hot. That same day, that same problem happened once again.
Being paranoiac now, I check my gauge oil temperature now and then, and it rises up to 250° after a 20-30 minute ride.
I went to the dealer, explained to him the failure I had and asked him about the "heat". Checked quickly and found nothing wrong. He explained to me some of the heat issues, that I have already been reading in this forum, about the new HD engines and the EPA regulations and why they produce so much heat. I asked him if changing mufflers, air cleaner things would go for the better, he answered yes but I won't be covered by the HD warranty.
Do you think my engine stalling is related to heat?
What should I do?
I am bit disappointed, after spending 20000$, that I have to be concerned about my engine if days are warm or my I'm driving in town!
Thanks in advance!
My bike came from the dealer with 2" rush pipes and I have yet to see over 225. Check your oil, look at the color. Pending your milage, it still should be transparent to a point.
I will be changing to synthetic, most likely redline.... I think that will dial it down a bit.... but i like the fact that it gets over 210 because it will get any water out. It not driven daily.
Their technical write-up will inform and advise. The bikes running hot now is normal, the engine gets MUCH hotter than the oil, (like 749 degrees F), and the oil will begin to breakdown above 300 degrees.
Switch all three holes to appropriate Amsoil and then get yourself pipes, a/c, and a fuel controller (FuelPak, SERT, PCiii, etc). The temps will come down, performance will improve, and you give up a little fuel mileage. Synthetic oils more the double the maximum operating temperature range of dino-juice.
Your symptoms were POSSIBLY the bike's built-in self-defense if one of the temp sensors kicked a high reading to the ECU.
I too live in Florida and have been riding everyday to work and back in record-breaking heat here in Central Florida. I haven't had any problems, and do notice running cooler now on synthetic lubes.
I am waiting on pipe info from V&H so I can do my exhaust/a-c/FuelPak changes. Harley won't warranty somebody else's stuff, and you may need to revert back to stock, but there have been many noteworthy cases where Harley will take care of the bike for folks who have stage 1 stuff done. (Its all about how you approach the dealer and what the problem actually turns out to be).
I wouldn't worry about your baby.
Cheers.
Roger
so it is normal to be running around 225?
I run Redline. Some like Amsoil or Mobil 1.
One of the site sponsors will give you 10 percent off cases and another 10 percent with the code mos10
http://www.myoilshop.com/
But thats on redline stuff...
He also said that for an additional Thousand dollars they could fix it so she could ride it on hot days.
I would really be disappointed if a brand new out of the factory 07 just stalls because it's warm outside. Or it is just me? You're paying so much money for a motorcycle, and it's not enough! to got it run properly, you need to add extras?!
I don't think that's normal...
