Big bore kit or new engine
Old Nov 16, 2022 | 06:19 PM
Swole2112's Avatar
Swole2112
Stage II
Default Big bore kit or new engine
I’ve got a 2008 Fatboy with about 68,000 miles. I was talking to a guy at a dealership service department about putting in a big bore kit when he warned me that doing that with such high miles would cause the engine to tear itself apart. He recommended either building a new motor and transmission or buying one. Is he right?
Old Nov 16, 2022 | 06:49 PM
Teufelhunden's Avatar
Teufelhunden
I'm FAR from an expert, but I would be hesitant to go big bore on a bottom end with 68,000 on the clock. Not sure I would be worried about the trans though.....Harley trannies seem to be pretty solid...at least they have been in the ~50 years that I've been owning/riding them.
YMMV
Old Nov 16, 2022 | 08:54 PM
hattitude's Avatar
hattitude
This is all IMHO...
There is some truth in what he is saying, but I will disagree with the "guy at the dealership service department"... There is more to an engine's ability to handle additional power, than just the mileage.
I agree that if the bottom end is loose, damaged, or badly worn.... the addition of a big bore kit most likely would be more than it could handle....
I will also agree that the higher an engine's miles, the more careful you have to be about adding power.....
But to make a blanket statement that a 68K engine will "tear itself apart", is a BS thing to say...
How big of a displacement increase? How much of a compression increase? How much of a HP/TQ increase...?
Unless he had worked on your engine and knew something specific about your engine's condition, or you were inquiring about a radical, high HP Big Bore Kit, it sounds like that "guy at the dealership service department" was trying to sell you something....
When speaking as an "expert", a true expert should be more careful with their words.... IMHO, his advice should have been offered as a risk v benefit discussion, or even a cost v benefit discussion, educating you about the potential risks..... rather than issuing a blanket doomsday statement...
There's a big difference between saying, "I wouldn't recommend it at that mileage", or "it may be better to", then to say it "would cause the engine to tear itself apart."
His "expertise" would have lost any credibility with me, due to that blanket statement....
Old Nov 16, 2022 | 09:29 PM
Swole2112's Avatar
Swole2112
Stage II
This is all IMHO...
I’m thinking of going from a 96 to a 103 and throwing in some screaming eagle racing cams.
This guy started by saying it would be better if I paid to have a new engine built and then said if I was going to do that, that I might as well just buy a brand new bike with one of the 114 Milwaukee 8 engines. So, his recommendation cost went from about $3K to about $6K to about $26K. That’s quite a jump.
Old Nov 16, 2022 | 10:17 PM
hattitude's Avatar
hattitude
Yeah, he was trying to make some money....
I have no idea about your riding habits, maintenance routine, or current mods.... so I hesitate to offer advice...
However.... if it were my bike, and...
I like the way it is set up...
I am planning on keeping it for awhile...
It is my one and only bike or reliability is extremely important...
I would rebuild the engine rather than adding a big bore kit at that mileage.
I would certainly consult a shop on what components in a big bore kit to choose, to reach my performance goals.... Consulting a shop is a good idea. You want components that work well together, If you just pick several brand name components and throw them together, you may be short changing yourself.... Most shops have combinations that they use and know work well together.. And as always, after all the mods are done, the tune is very important...
Depending on the planned HP increase, I would probably also spend the money to have the bottom end done by someone like Darkhorse Crankworks, then do the new top end myself...
I would then have an extremely solid, well built engine that IMHO, would be better than any OEM HD engine... It would certainly be much cheaper than a new M8... and (depending on component choices) it would run every bit as good as an M8...
If I was just doing mods on a 2nd bike, and/or one that's mostly a local cruiser, I would first check the crank runout. If runout was good, I'd just do a Stage II with a bolt-in cam. I'd get it tuned well by a reputable tuner.... then run it...
Good luck with your decision(s)....
Old Nov 18, 2022 | 03:16 PM
Rains2much's Avatar
Rains2much
I’m reluctant to give any advice on an m8 or Twinkie because I’ve never been inside one. However.. a motor is a motor is a motor. If this was an EVO, I’d say if you can do some labor yourself, I’d get heads ported, good valve job, new springs and cam(s), hone (depending on the cylinders) and just get higher compression pistons. This way not a lot of money is thrown on top of a half used bottom end and the power gain would be good with little investment. Then in another 50,000 just buy a crate engine or sell the bike.
I would not pay for all that labor and new parts of big jugs on a bottom with close to 70k on it.
Old Nov 20, 2022 | 03:16 AM
Zakk13's Avatar
Zakk13
I’m thinking of going from a 96 to a 103 and throwing in some screaming eagle racing cams. This guy started by saying it would be better if I paid to have a new engine built and then said if I was going to do that, that I might as well just buy a brand new bike with one of the 114 Milwaukee 8 engines. So, his recommendation cost went from about $3K to about $6K to about $26K. That’s quite a jump.
Can't Imagine an engine tearing itself apart going from a 96 to a 103. That's a slight bump 10hp/10tq give or take. If anything it will refresh the top end. With that said once you get up there in mileage you really need to know the condition of your engine before doing any kind of internal modifications. Sounds like the stealership just wants you to dump $26k on a new M8.
Old Nov 28, 2022 | 05:45 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Start with checking the run out on the pinion shaft.. If you're at .003-.005".I would go for it.. I'd also go with a Andrews TW 48, Wood tw 222, or tw 5-6..
Trans should be fine..
Old Nov 30, 2022 | 08:30 AM
ChromeJunkie's Avatar
ChromeJunkie
I say do the big bore kit if that’s what you want to do. I had a S&S 97 inch big bore installed on my 06 Heritage a few years ago with close to 90K on the clock and have had zero issues. I also went with the Screamin Eagle ported heads and already had 510 gear drive cams installed. I’m calling bullshit on the dealer telling you it will tear itself up. Sounds like a sales ploy to me.
Fletch19
Jul 12, 2022 02:04 PM
AbitNutz
Milwaukee Eight (M8)
19
Oct 31, 2019 11:47 AM
clprfan15
Feb 16, 2012 01:07 AM
Plow64
EVO
18
Feb 5, 2011 02:06 PM
Tattooedlife
EVO
May 18, 2008 07:08 PM
