Cam chain tensioners
Do these things ever really fail or is this preventative?
However, there have been enough failures, that the MoCo redesigned that part of the Twin Cam engine.... That is not an inexpensive solution...
IMHO... this is a case of the stakes being more important than the odds... By that I mean, the odds probably aren't great that the tensioners will absolutely fail happen, but what's at stake if it does happen is pretty serious... There can be a very significant difference in the cost of repairs between a preemptive changeout of the cam tensioners, and repairing an engine where they have failed... I believe with the age of these engines, the odds are increasing...
In just my limited anecdotal experience, three out of three bikes I inspected with the spring tensioners and link chains, I have felt all needed to have the tensioners replaced, because they were in jeopardy of failing.
My three observations involved low mileage bikes, but with 15+ years of service. It is my opinion, that with age and heat cycles, the OEM tensioner pads get brittle, which puts them at risk of breaking apart, even if the actual wear isn't substantial. Even if they don't break apart, those small pieces that break off from the pads could cause issues. If one comes to rest in a lifter, it could reduce and/or stop oil flow to the rockers...
The last cam chest I upgraded was just last week. It was an '04, EFI, Stage I engine with 19,900 miles on the bike. Here are the tensioners I removed and replaced. I would not have wanted to be driving around with these tensioners in any of my bikes...
I believe they are just too easy, and depending on your choice of updates, also fairly cheap to replace, rather than to ignore them or just "roll the dice"....
My '00 Classic had new ones installed at 40,000 during a service,they were toast 60K later at 100,000 miles and I went gera drive.
I just changed the shoes on my 02 Road king - here is the thing, if you do these upgrades or change the shoes often (I do) then you already have the tools.....however, if this is your first go around changing just the shoes, its not really that cheap. By the time you buy the cam bearing tool (ebay for $60-$75) , the shoe removal tool (Vtwin Mfg - $145) & the install tool ($36 +/-) you`ll have a little money spent right there. the shoes are only like $15 - $20 dollars with shipping but after you buy the inner bearings, Orings, gaskets, lifters (should change) adjustable PS if you go that route? oil, oil filter (Id do an oil change) etc... you`ll have some money in it - but better than not doing it cause that will cost way more.
