Fatboy/HP/torque?
Old Aug 20, 2007 | 11:51 PM
mentor70's Avatar
mentor70
Default RE: Fatboy/HP/torque?
here is a Head quarters 95, similar to thebuild that I have.
10.5 compresion, ported heads, .575 GD cams, 2 to 1 thunderheader.
Mikuni 42, with HQ ignition
Old Aug 21, 2007 | 05:01 AM
Heritage07's Avatar
Heritage07
'07 Heritage with Stage 1 Rush 2.0 and Sert. 76 hp 87 tq
Old Aug 21, 2007 | 10:04 PM
RiggidyRaw's Avatar
RiggidyRaw
You were right about compression. Less wear and tear on the engine.Lower compression is always a good choice if it gets you the results you want.
Old Aug 21, 2007 | 11:01 PM
sonar_chris's Avatar
sonar_chris
ORIGINAL: mentor70
Your air fuel ratio is all over the place, if you can smooth that out youll have a lot nicer torque curve to play with.
Chris
Old Aug 21, 2007 | 11:23 PM
mentor70's Avatar
mentor70
The blue lines are the "after" tuning lines, the reds are the before.
As for the Torque, for a 95 in. I dont think it gets much better than that!
Old Aug 22, 2007 | 11:31 PM
Jucifer's Avatar
Jucifer
ORIGINAL: RiggidyRaw
Thanks. That tank looks bad A$$
Old Aug 22, 2007 | 11:50 PM
mgmmgm's Avatar
mgmmgm
Hi-Have 07 Fatboy, I am running V&H pipes staggered big shots and SE A/C and SERT with dyno tune by stealer at 1K miles
Max power is 74.21 and Max Torque is 84.21 A/Fuel 13.3 approx
run condition was 72 degrees 28 .00in Hg Humidity 15% SAE 1.05
Old Aug 23, 2007 | 12:28 AM
mentor70's Avatar
mentor70
I say do what feels right for you, and what you feel gives you the most value for your $$$!
I dont think one point of compresion means jack on wear and tear, its all in the tune and the maintance that follows.
The choice in your builder/machinist and parts selection has a dominant factor here too!
Old Aug 23, 2007 | 01:00 AM
FXST's Avatar
FXST
ORIGINAL: mentor70
They are great figures. The torque is where you feel the grunt. I think the 2 into 1 makes a huge differance in power and torque as well. Mine hasa 95 cube, 42mm Mikuni,10.5 comp, heads flowed and cams standard for 89hp and 93ft lb torque. Cams are my next engine mod....
Old Aug 23, 2007 | 01:04 AM
mentor70's Avatar
mentor70
^^^Love your wheels!! paints great too!
Let us know what you choose for cams! and what you get for results.
