Atlas throttle lock
Old Jan 8, 2023 | 11:35 AM
BFREE's Avatar
BFREE
I use the KLEVER LEVER from J&P Cycles.
Old Jan 8, 2023 | 12:32 PM
T^2's Avatar
T^2
Originally Posted by Andy from Sandy
From HD manual - Do not tighten throttle friction adjustment screw to the point where the engine will not return to idle automatically.
Naturally - for normal operation/riding - you wouldn't adjust the friction adjustment screw so that it would prevent (or bind) the throttle from returning to idle. In fact, when installing devices like the Throttle Tender or the KLEVER LEVER, the friction adjustment screw is set specifically so that it doesn't inhibit the throttle return. These things just allow you adjust the friction adjustment screw a tad more on the fly so that it will (barely) hold the throttle. This may not be the design intent of the friction adjustment screw, but it works OK. Used judiciously... it's not likely - in my opinion - to cause a problem.
Old Jan 8, 2023 | 02:21 PM
Sarge Fatboy's Avatar
Sarge Fatboy
Love J&P Cycles! I took my thumb **** off when I switched out black controls to chrome and just forgot to put it back in and now since I need to go back in there I thought I would change to Cruise Mate as it seems a little more adjustable and is available in chrome which I like.
bulldog1776
Jul 4, 2021 07:35 PM
Mcdave
Feb 11, 2014 06:08 PM
FBFletch
Sep 29, 2011 07:28 PM
scomike
Sep 15, 2010 11:06 AM
WarBootie
Jul 29, 2009 09:03 AM
