Another Dreaded Click, Click...
Old Jul 28, 2023 | 01:42 PM
  #161
mikey95hd's Avatar
mikey95hd
Wired a 14 gauge wire from sliver stud to pin 30 on starter relay, connected everything back up, hit starter, and now she's cranking. I did put a quart of oil in the tank and have turned it over about 8 times now. No difference in the oil level in the tank. Also probably need to change spart plugs since it tried to fire with fogging oil in the cylinders.
Old Jul 28, 2023 | 01:47 PM
  #162
mikey95hd's Avatar
mikey95hd
Thanks for the advice, and my apologies for being such a *******. Just was frustrated with the situation.
Old Jul 28, 2023 | 02:21 PM
  #163
mikey95hd's Avatar
mikey95hd
I just hit the start button, with ignition switch in off position, and it cranks, and actually started. after cleaning plugs with contact cleaner.
Old Jul 28, 2023 | 03:01 PM
  #164
Jackie Paper's Avatar
Jackie Paper
Originally Posted by mikey95hd
I got one without the diode, when I turned on the switch two click nothing, one click back and I heard the relay click, it's a DC circuit. Diode only allows electricity to flow one direction, no diode it flow either way. Path of least resistance.
Yes, know what a diode does. It also turns AC to DC . Not sure on a relay their why. Should not be any DC going both directions there.
Diodes are in voltage regulator for the AC coming out of alternator. There also in the ECM to prevent damage from someone putting a battery in wrong.
I have also seen them in the relays on my Toyota under hood fues box on the fuel pump relay. In this case, it has no timer. It uses two relays. One works on crank circuit. Other when running from ECM ground.
There in line, so I see that need. Guess same applies in your bike
Old Jul 28, 2023 | 03:07 PM
  #165
mikey95hd's Avatar
mikey95hd
Well this is the way it's setup on this bike, one diode in the starter relay. If I remember correctly you have to have four diodes to convert AC to DC. It's called a full bridge rectifier.
Which is what the voltage regulator does in this situation, it comes out the stator as AC and the regulator converts it to DC which then feeds to the circuit breaker and then to the battery to charge it.
Old Jul 28, 2023 | 03:37 PM
  #166
mikey95hd's Avatar
mikey95hd
Just tried starting again, looking inside oil tank with dipstick out and added only one quart to tank. Bike now starts and runs, however don't see the oil flowing in the tank and looks clean when checking with screw driver.
Old Jul 28, 2023 | 06:14 PM
  #167
Jackie Paper
Early Harley's were two phase coming out of alternator. Know mine is three seperate AC lines and I assume 3 phrase.
Now when you are referring to bridge, I assume each line has a diode.
AC/DC/ National Electric Codes was a side classes for my mechanic side.
So I will just go with it. My first response was I know sometimes, a diode can short across rather then burn out. AC coming into DC electronics is not good. Especially modern bikes with ECM and BCM
Appears in your diagram, you have a two phase alternator AC going to DC output and then the voltage regulator.
Those two extra diodes are to not let say to 30 Volt AC become 60 Volt AC and then be DC.
In my higher AMP 3 phase, a bridge would be 6 diodes.
Old Jul 28, 2023 | 06:33 PM
  #168
springers4ever's Avatar
springers4ever
Cool Negative side ...
Have you tried taking the negative side (or the ground side) from the starter relay straight back to the negative side of the battery ...they used to ground it to the oil tank which is rubber mounted to the frame (on most softails) ....causing a somewhat bad connection over time ... which has caused the ( dreaded EVO click )
Old Jul 31, 2023 | 04:37 PM
  #169
mikey95hd's Avatar
mikey95hd
I looked at the ground it comes out of the plug to the back of the frame mount behind the oil tank...
Old Aug 5, 2023 | 02:10 PM
  #170
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The starter motor should not crank with the key switchin the off position.
Let`s start tracing the wiring for the ignition switch.
First, trace the wire that runs from the main breaker silver stud to the ignition switch tab "A".
Last edited by Dan89FLSTC; Aug 5, 2023 at 02:35 PM. Reason: Edited to correct to silver stud.
