Another Dreaded Click, Click...
Old Aug 5, 2023 | 02:14 PM
  #171
mikey95hd's Avatar
mikey95hd
The starter motor should not crank with the key switchin the off position.
Let`s start tracing the wiring for the ignition switch.
First, trace the wire that runs from the main breaker copper stud to the ignition switch tab "A".
​​​​​​​That wire goes to the silver stud. Not the copper.
Should I disable the circuit we added to pin 30 from the silver stud on the main breaker?
Old Aug 5, 2023 | 02:35 PM
  #172
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Silver stud is correct, I goofed up my text, it has been edited to silver stud.
Old Aug 5, 2023 | 02:38 PM
  #173
mikey95hd's Avatar
mikey95hd
Do you want me to check voltage at "A" or at the circuit breaker?
Old Aug 5, 2023 | 02:40 PM
  #174
Dan89FLSTC's Avatar
Dan89FLSTC
Next wire to check:
Old Aug 5, 2023 | 03:14 PM
  #175
mikey95hd's Avatar
mikey95hd
Next wire to check:
That one looks good, also have cleaned all the wires at the ignition switch.
12.46 volts at battery, 12.46 at "A", and 12.46 at "E"., With key in on position drops to 11.99...
Old Aug 5, 2023 | 05:30 PM
  #176
Dan89FLSTC's Avatar
Dan89FLSTC
Keep in mind, there is something wired wrong somewhere, so look carefully when you trace the wires.
Next wire to check:
Old Aug 5, 2023 | 05:43 PM
  #177
mikey95hd's Avatar
mikey95hd
Next wire to check:
That wire looks to be connected properly.
Also found the gray wire, had tape around it. So took tape off and looked like a mess, so I cut and spliced the wire. Also looking carefully for anything that looks wrong...and looking at the wiring diagram.
Also fired it up with the wire attached, from pin 30 to silver stud, I put a switch on the added circuit. Turned it to run position, fired right up, and killed circuit with switch, voltage regulator and stator are putting out battery now reads 12.79 volts.
Old Aug 5, 2023 | 06:20 PM
  #178
mikey95hd's Avatar
mikey95hd
Also the ignition is not stock, it has the single fire S&S HI-4N.
Old Aug 5, 2023 | 06:37 PM
  #179
mikey95hd's Avatar
mikey95hd
Old Aug 5, 2023 | 08:14 PM
  #180
mikey95hd's Avatar
mikey95hd
At least it runs, that is making progress,...still can't figure out why it's running with the ignition switch in the off position. Haven't found anything yet with the wiring harness being wrong.
