Another Dreaded Click, Click...
Old Jul 20, 2023 | 01:25 PM
  #71
mikey95hd's Avatar
mikey95hd
Mikey, sorry I posted the wrong pic of ignition switch, I will post correct illustration shortly.
You should remove the wires at the ignition switch, one at a time, and clean the contact surfaces.
Same for the wires at the circuit breakers, especially the ignition breaker.
I'm not sure where is the ignition breaker?
Will clean wires at ignition switch.
Old Jul 20, 2023 | 01:26 PM
  #72
mikey95hd's Avatar
mikey95hd
I just replaced the switch, my brother wouldn't give me the key.
  #73
WP50's Avatar
WP50
Maybe disconnect battery while at this ??
Ahh he may have already thought about it
WP
Old Jul 20, 2023 | 01:30 PM
  #74
WP50's Avatar
WP50
Are the pics above the bike your working on?
OEM switch
Old Jul 20, 2023 | 01:34 PM
  #75
mikey95hd's Avatar
mikey95hd
OEM switch
Yes it's not the original, it's a drag specialist switch, however when I took it to a shop they replaced the switch, and everything was working great, that was over two years ago. New switch looked exactly the same as newer switch.
Old Jul 20, 2023 | 01:39 PM
  #76
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
WP
Thanks WP, I got ahead of myself, good catch!
Old Jul 20, 2023 | 01:40 PM
  #77
Dan89FLSTC's Avatar
Dan89FLSTC
Mikey, PLEASE disconnect the negative battery cable before cleaning the connections at the switch and the breakers (again, thanks WP).
When you clean those connections, look for damage on the wires at the connectors, sometimes the wire breaks (or partially breaks) right there.
Old Jul 20, 2023 | 01:45 PM
  #78
WP50's Avatar
WP50
if I'm looking right and remember the breakers are just below the ing switch between the tanks in you pic
WP
Old Jul 20, 2023 | 01:50 PM
  #79
Dan89FLSTC's Avatar
Dan89FLSTC
WP
Yes, just follow the red/black wire from the ignition switch.
Old Jul 20, 2023 | 03:33 PM
  #80
mikey95hd's Avatar
mikey95hd
​​​​​​ Cleaned all the wires on the ignition switch, they looked good since I replaced the switch last week, no breaks, all looks good, just need to take off those on the relay under the ignition switch next, it's in the direct sunlight right now 99 degrees here in komifornia.
