Another Dreaded Click, Click...
Old Jul 20, 2023 | 03:42 PM
  #81
Jackie Paper's Avatar
Jackie Paper
Originally Posted by mikey95hd
Well the new relay is a joke, when you turn the ignition on nothing, and when going to off position, the first turn counter clockwise there is a click, that isn't right at all.
Put original relay back in, now same results when holding start switch, drops to 7.58 now and voltage has dropped to 12.58...
Pretty obvious, at that 7.58, the starter motor is trying to run. Obliviously it's the starter motor. It might not have the amps from a bad battery to crank it but starter should spin till it hits ring gear
You need to take starter off and bench test it. However this thread has gotten so long, I have forgotten were we came from now
Credit to you guys that have the wire colors memorized. I sometimes think we are on Mel Gibson/Danny Glover Lethal Weapon Move.
We are going to get this one. Rarely do I see a USER keep trying like this.
Most declared defeat, haul their basket case in and thread dies.
Way To Go Mikey!
Old Jul 20, 2023 | 04:02 PM
  #82
mikey95hd's Avatar
mikey95hd
Way To Go Mikey!
Well I'm not sure at this point, looks to me that the starter just isn't working properly. It was bench checked, from the builder. Everything looks good on paper, however I don't think they put a load on it
Also new relay doesn't have a diode. The original has one.
Old Jul 20, 2023 | 04:31 PM
  #83
mikey95hd's Avatar
mikey95hd
Maybe?
At least it has a warranty!
Old Jul 20, 2023 | 04:49 PM
  #84
Tom H's Avatar
Tom H
New starter relay seems to be a dud. When you cycle the ignition switch to OFF and hear a click, did you confirm it was coming from the relay?
The green wire to the starter solenoid. When you get the about 7.5V, that is with the green wire connected to the solenoid right? What do you get when it's not plugged in to the solenoid? I think you also mentioned that the green wire had no power at one point. You moved some wires and now it has power. The voltage drop could be due to the wire itself or one of the connectors that it has being damaged or corroded.
Is the bike's starter, clutch and all together enough to try bypassing the green wire? I can't remember if you tried running a wire direct from the battery + to the solenoid where the green wire plugs in. If you try this, MAKE SURE your in neutral.
Just a thought,
Tom
Old Jul 20, 2023 | 04:50 PM
  #85
Jackie Paper
I love it. Computer tested.
Have you seen it run?
Old Jul 20, 2023 | 05:11 PM
  #86
mikey95hd's Avatar
mikey95hd
Yes with nothing connected to it in the inner primary case. It screams, and with the jackshaft in, it did turn the jackshaft a couple of times, then it clicked after that, so that also is pointing to the starter.
Old Jul 20, 2023 | 05:21 PM
  #87
Jackie Paper
Very possible it thru some soldered wires out of the commentator. Manual turn it and see if it will go. It's obviously drawing battery down.
Could be just acting like a big magnet stuck with the next tug dead.
Old Jul 20, 2023 | 05:27 PM
  #88
mikey95hd's Avatar
mikey95hd
I tried turning it when I installed the jackshaft, it did turn the starter when I tightened the jackshaft with a socket wrench 1/4 drive pretty easily.
Old Jul 20, 2023 | 05:37 PM
  #89
WP50's Avatar
WP50
If everything is back together and you haven't found much you can point a finger at
Doing this ain't for everyone but I have done it a number of times over the years.
It's not consider a good way but it works
Would you have a extra terminal that fits the solenoid connection. if so put it on a length of say 12 ga. stranded wire
Plug it on the starter and brace for some sparks put the other end of the wire against the positive battery terminal.
Very very shadtree way to ck something and you maybe hesitate to do it and that's fine . Just keep plugging along
Yup burned some fingers doing it
WP
Post 84 was going the same direction .
Old Jul 20, 2023 | 05:55 PM
  #90
mikey95hd's Avatar
mikey95hd
Just a thought,
Tom
With green wire disconnected voltage reads 11.68, battery voltage is now at 12.56 at battery . With wire connected still only 7.68 volts. So there is a 4 volt drop when connected to the solenoid. Just connected everything back up and that's the current readings.
