Another Dreaded Click, Click...
Tom
You said it had spun up before. That's when I was thinking a improperly soldiered wire came loose. The armature becomes many indexing magnets as it spins.
There are outer field coils, either electrical or in some cases strong permanent magnets are used .
The commutator is a bunch of seperate connections that the brushes run on to index the pulls.
Wasn't saying armature would not turn. Was saying it had broken and the required next tug was missing.
Seen this happen on car starters. Sometimes spinning it will get it to run. Of course that doesn't fix it and starter is very weak.
You would see it in an amp draw test.
What is the voltage reading across the battery posts while the start button is pressed?
Next step, unplug the electrical connector under the dash panel, clean the pins and sockets in the plastic connector, make sure none of the pins or sockets are pushed out of the connector.
That to me is starter or battery.
That connector is the one under the gas tank correct? I had that half off the other day when cleaning the contacts on the ignition switch, dropped one of the little screws down in that area. At that time didn't think to look at that connector, since that is the path for the power on the red wire.
Will do another voltage check at the battery, and pressing the start button again, I know the voltage is getting low on the battery, maybe take it to auto zone again and have them charge it up again, seems
you can't find a good battery charger nowadays.
Also found the same wiring diagram that you have.
Have seen that voltage many times start vehicle or bike if enough amps still in the battery
Real curious as to what battery voltage is with/without the button pressed.
Goodness I'm wondering how many amps the starter is really pulling.
OP Takes a different kind of meter
WP
https://www.harborfreight.com/2815-a...ger-56796.html
Tom
Pressing start button 11.68 volts
cleaned the connector that goes thru the frame under the dash, no loose pins in connector, and no chaffed or broken wires, and took red/black wire off the ignition relay and cleaned it again...
Connected everything back up again, connected battery positive connector at battery. Hit starter button, and guess what, the starter engaged, the jackshaft engaged the clutch gear, and the engine turned over, if there was gas in it I'm sure it would have started. Turned it off, thinking maybe it's now going to work. Well waited 5 minutes and tried it again, now it just clicks again at solenoid.
Battery voltage is 12.38, 11.70 when press start button.
At least we're making progress now, that's the first time everything seemed to work like it should, at least one time.
Two more connections to clean up (they will be fun), on the main breaker.
It is back on the rear fender extension, you can pull it out of its bracket and pull it toward you to get access to the tiny nuts.
You`re doing good Mikey.
Note: You need to charge that battery, it is weak.
